| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to change the values assigned to an FTP server using the chg-ftp-serv command.
The chg-ftp-serv command uses these parameters.
:app – The application of the FTP server. There are four values for the app parameter:
meas – The FTP servers for the Measurements Platformdb - The FTP server for the database backup/restore application.dist - the FTP server for the EAGLE software release distribution application.user – The FTP servers for the FTP Retrieve and Replace feature.Caution:
While this procedure can be used to change a USERFTP server configuration, any USERFTP server configurations changed by this procedure will be overwritten by the FTP server configuration information sent to the EAGLE by the EAGLE FTP Table Base Retrieval (FTRA).:ipaddr – The IP address of the FTP server.
:login – The name of the FTP server client.
:path – The path to the file on the EAGLE that is to be sent to the FTP server.
:prio – The priority of the FTP server, from 1 to 10.
The app and ipaddr parameters must be specified with the chg-ftp-serv command. The IP address of the FTP server cannot be changed with the chg-ftp-serv command. If you wish to change the IP address of the FTP server, the FTP server must first be removed with the Removing an FTP Server procedure, then re-entered with the new IP address using the Adding an FTP Server procedure.
The login parameter value can contain from 1 to 15 alpha-numeric characters. The alphabetic characters can be both upper and lower case characters.
The path parameter value is a mixed-case quoted character string with a valid FTP path format that can contain up to 100 characters.
If the login parameter value is changed, the user is prompted for a password for this FTP server. The password can contain from 1 to 15 alpha-numeric characters. The alphabetic characters must be both upper and lower case characters. The password is not shown on the terminal screen as it is being entered and is not shown in the rtrv-ftp-serv output.
If the Eagle OA&M IP Security Enhancement Controlled Feature is enabled and activated, the FTP servers configured in this procedure must be secure FTP servers. The EAGLE FTP Table Base Retrieval (FTRA) and the Measurements Platform must support secure shell connections to the EAGLE. Enter the rtrv-ctrl-feat command to verify whether or not the Eagle OA&M IP Security Enhancement Controlled Feature is enabled and activated.
Because CSV measurement data files do not have unique names across multiple STPs, include the CLLI of the STP in the FTP server path for meas FTP servers.
Figure 4-25 Changing an FTP Server
Sheet 1 of 2
Sheet 2 of 2
