| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to make a backup of the database on the fixed disk using the chg-db command with action=backup and dest=fixed parameters.
The databases in the current partitions of both MASPs (FD CRNT) must be coherent. For more information on verifying the database, refer to Verifying the Database.
Figure 2-4 Making a Backup of the Database on the Fixed Disk
