| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
When the database is backed up to the FTP server, the release number string of the file name that is created is either the software release number or the software build number. The archbldid value of the on or off parameters of the chg-stpopts command determines which number is used as the release number string.
on=archbldid parameter is specified, the software build number is used as the release number string. off=archbldid parameter is specified, the software release number is used as the release number string.The system default value for the archbldid parameter is off .
Figure D-5 Configuring the Archive Build ID Option
