Go to primary content
Oracle® Communications EAGLE Database Administration - System Management User's Guide
Release 46.8
F11885 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Activating the Fan Feature
This procedure is used to activate the fan using the chg-feat command with this parameter.
  • fan=on - turns the fan on. When the fan is turned on, system cards and functions that generate heat in the EAGLE can function properly.
  1. Enter the rtrv-feat command to check the status of the Fan feature.
    The rtrv-feat command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rtrv-feat command, see the rtrv-feat command description in Commands User's Guide.
  2. If the fan feature is not on, use the chg-feat:fan=on command to turn on the fan.
  3. Verify the changes using the rtrv-feat command.
