| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to configure IP communications links between the EAGLE and the customer’s network and enable the Measurements Platform on the EAGLE using these commands:
ent-ip-host – Configuring the IP host of the MCPMchg-ip-card – Configuring the IP address of the MCPMchg-ip-lnk – Configuring the IP link assigned to the MCPMchg-measopts – Enabling the Measurements Platform option These commands contain parameters that are not used in this procedure. Commands User's Guide contains a full description of these commands.
The Measurements Platform requires measurements FTP servers. A maximum of three measurements FTP servers can be configured with one of these procedures.
MCPMs must be configured in the database before this procedure can be performed. This can be verified with the rtrv-card command.
If a Class B IP address is specified for the ipaddr parameter of the chg-ip-lnk command, the subnet address that results from the ipaddr and submask parameter values cannot be the same as the subnet address that results from the pvn and pvnmask, fcna and fcnamask, or fcnb and fcnbmask parameter values of the chg-netopts command. The pvn and pvnmask, fcna and fcnamask, or fcnb and fcnbmask parameter values can be verified by entering the rtrv-netopts command. Choose ipaddr and submask parameter values for the IP link to the MCPM whose resulting subnet address is not be the same as the subnet address that resulting from the pvn and pvnmask, fcna and fcnamask, or fcnb and fcnbmask parameter values of the chg-netopts command.
Figure 4-22 Configuring the Measurements Platform Feature
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
