| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to add an Measurement Collection and Polling Module (MCPM), used for the Measurements Platform feature, to the database using the ent-card command. The MCPM provides an interface between the EAGLE and the customer’s network. The Measurements Platform provides a dedicated processor for collecting and transferring measurements data to a customer supplied FTP server.
The ent-card command uses these parameters.
:loc – The location of the card being added to the database.
:type – The type of card being added to the database. For this procedure, the value of this parameter is mcpm.
:appl – The application software that is assigned to the card. For this procedure, the value of this parameter is mcp.
The Measurements Platform feature requires a minimum of two MCPM cards (part number 870-2372-03 or later) with at least 2 GB of memory per card or two E5-MCPM-B cards with at least 4 GB of memory per card. The MCPM and E5-MCPM-B cards can also be used in mixed mode.
The Measurements Platform feature must be on in order to add a MCPM to the database. This can be verified with the rtrv-feat command. To enable the Measurements Platform feature, the measplat=on parameter must be specified with the chg-feat command.
The Measurements Platform feature must be purchased before turning on the feature. If you are not sure whether you have purchased the Measurements Platform feature, contact your Oracle Sales Representative or Account Representative.The shelf to which the card is to be added, must already be in the database. This can be verified with the rtrv-shlf command. If the shelf is not in the database, see the Adding a Shelf procedure.
After all required MCPMs have been configured in the database, go to theConfiguring the Measurements Platform Feature procedure and configure the IP links for these MCPMs and enable the Measurement Platform feature, if necessary.
The examples in this procedure are used to add an MCPM in card location 2107.
Before executing this procedure, make sure you have purchased the Measurements Platform feature. If you are not sure whether you have purchased the Measurements Platform feature, contact your Oracle Sales Representative or Account Representative.Figure 4-20 Adding a Measurement Collection and Polling Module (MCPM)
Sheet 1 of 2
Sheet 2 of 2
