| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
|  Previous |  Next |
This procedure is used to add a shelf to the database using the ent-shlf command. The shelf may not already exists in the database. The control shelf (Shelf 1100) cannot be added to the database. The ent-shlf command uses these parameters.
:type – The shelf type. There is only one shelf type that can be added to the database, an extension shelf, shown by the value for this parameter as ext.
:loc – The shelf location
The examples in this procedure are used to add an extension shelf to frame 3 of the EAGLE.
Figure 4-13 Adding a Shelf
