Go to primary content
Oracle® Communications EAGLE Database Administration - System Management User's Guide
Release 46.8
F11885 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Removing a Shelf
This procedure is used to remove a shelf from the database using the dlt-shlf command. If the shelf to be removed does not exist in the database, it cannot be removed. The control shelf (Shelf 1100) cannot be removed from the database. The dlt-shlf command has only one parameter, loc, which is the location of the shelf.
Before a shelf can be removed from the database, all of the cards in that shelf must be removed from the database. The procedures for removing these cards are based on the application that is assigned to these cards. Table 4-3 shows the location of these procedures.
Table 4-3 Card Removal Procedures
Card Application Procedure
SS7ANSI, ATMANSI, CCS7ITU, ATMITU
“Removing an SS7 LIM”
"Removing an E1 Card" in the Database Administration - SS7 User's Guide
"Removing a T1 Card" in the Database Administration - SS7 User's Guide
VSCCP
"Removing a Service Module" in the Database Administration - GTT User's Guide
GLS
"Removing a GLS Card" in the Database Administration - GWS User's Guide
STPLAN
"Removing an STP LAN Card" in the Database Administration - Features User's Guide
IPLIM, IPLIMI, SS7IPGW, IPGWI
"Removing an IPLIMx Card" or "Removing an IPGWx Card" in the Database Administration - IP7 User's Guide
IPSG "Removing an IPSG Card" in the Database Administration - IP7 User's Guide
EROUTE
“Removing an STC Card” in the Database Administration - Features User's Guide
MCP
“Removing an MCPM”
IPS
“Removing an IPSM”
Caution:
If any card in the shelf is the last card of that type in service, removing that card from the database will cause the traffic handled by that card to be lost or the feature requiring that card to be disabled. See Table 4-4 for a description of the effect that removing the last card type that is in service has on the EAGLE.
Table 4-4 Effect of Removing the Last In-Service Card Type from the Database
Card type Application assigned to card Effect on the EAGLE
LIMDS0, LIME1, LIMT1, LIMCH
SS7ANSI
ANSI traffic is lost.
LIMATM
ATMANSI
LIME1, LIMT1, LIMCH
CCS7ITU
ITU traffic is lost.
LIME1ATM
ATMITU
DSM
VSCCP
Global title translation traffic is lost. If any of the GTT-related features are enabled, the traffic for those features is also lost. Refer to the "Adding a Service Module" procedure in the Database Administration - GTT User's Guide for a list of the GTT-related features.
TSM
GLS
Gateway screening feature is disabled.
DCM
STPLAN
STPLAN feature is disabled.
DCM
IPLIM
Point-to-point connectivity for IP7 Secure Gateway functions in ANSI networks is disabled.
IPLIMI
Point-to-point connectivity for IP7 Secure Gateway functions in ITU networks is disabled.
SS7IPGW
Point-to-multipoint connectivity for IP7 Secure Gateway functions in ANSI networks is disabled.
IPGWI
Point-to-multipoint connectivity for IP7 Secure Gateway functions in ITU networks is disabled.
ENET IPSG Traffic carried by the IPSG card is lost.
STC
EROUTE
Monitoring of the EAGLE by the EAGLE 5 Integrated Monitoring Support feature is disabled.
MCPM
MCP
The Measurements Platform feature is disabled.
IPSM
IPS
IP Telnet sessions and the IP User Interface (Telnet) feature are disabled.
The shelf being removed in this procedure cannot be removed if the shelf is the only provisioned shelf in the frame and the frame is in the Frame Power Alarm Threshold table. The Frame Power Alarm Threshold table is shown in the rtrv-frm-pwr command output. If the frame is shown in the rtrv-frm-pwr output, and the shelf is the only shelf in the frame, perform the Removing an Entry from the Frame Power Alarm Threshold Table procedure to remove the frame from the Frame Power Alarm Threshold table.
The examples in this procedure are used to remove shelf 2100 from the database.
  1. Display the cards in the database using the rtrv-card command.
    This is an example of the possible output.
    rlghncxa03w 09-05-01 09:12:36 GMT EAGLE5 41.0.0
    CARD   TYPE      APPL      LSET NAME     LINK SLC LSET NAME     LINK SLC
    1101   DSM       VSCCP
    1102   TSM       GLS
    1113   GSPM      OAM
    1114   TDM-A
    1115   GSPM      OAM
    1116   TDM-B
    1117   MDAL
    1201   LIMDS0    SS7ANSI   sp2           A    0   sp1           B    0
    1202   LIMDS0    SS7ANSI   sp4           A    0
    1203   LIMDS0    SS7ANSI   sp3           A    0
    1204   LIMDS0    SS7ANSI   sp3           A    1
    1205   LIMDS0    SS7ANSI   nsp3          A    0   nsp4          B    0
    1206   LIMDS0    SS7ANSI   nsp3          A    1   nsp4          B    1
    1211   DSM       VSCCP
    1212   TSM       GLS
    1215   DCM       STPLAN
    1301   LIMATM    ATMANSI   lsnatm1       A    0
    1305   DCM       STPLAN
    1307   LIMDS0    SS7ANSI   sp2           A    1   nsp3          B    2
    1308   LIMATM    ATMANSI   lsnatm1       A    1
    1317   DCM       STPLAN
    2101   LIMDS0    SS7ANSI   sp5           A    0   sp8           B    0
    2102   LIMDS0    SS7ANSI   sp7           A    0
    2103   LIMDS0    SS7ANSI   sp6           A    0
    2104   LIMDS0    SS7ANSI   sp6           A    1
    2105   LIMDS0    SS7ANSI   nsp3          A    0   nsp5          B    0
    2106   LIMDS0    SS7ANSI   nsp3          A    1   nsp5          B    1
    In this example, these cards must be removed from the database: 2101, 2102, 2103, 2104, 2105, 2106.
  2. Based on the application assigned to the cards in the shelf to be removed, perform the appropriate procedures shown in Table 4-3 and remove all the cards from the shelf.
    The application assigned to the card is shown in the APPL field of the rtrv-card command output in step 1.
  3. Display the shelves configured in the database by entering the rtrv-shlf command.
    rlghncxa03w 06-10-01 09:12:36 GMT  EAGLE5 36.0.0
    SHELF DISPLAY
    FRAME SHELF        TYPE
      1     1       CONTROL
      1     2       EXTENSION
      1     3       EXTENSION
      2     1       EXTENSION
    If the rtrv-shlf output shows the shelf being removed in this procedure is not the only shelf in the frame, skip step 4 and go to step 5.
  4. Display the frame power alarm thresholds by entering the rtrv-frm-pwr command.
    Frame              Power Threshold (Amps)
    cf00                                   56
    ef00                                   36
    If the frame containing the shelf being removed in this procedure is shown in the rtrv-frm-pwr output, the frame must be removed from the frame power alarm threshold table (shown in the rtrv-frm-pwr output) before the shelf can be removed. The following list shows the frames and the shelves contained in those frames.
    • Frame CF00 – Shelves 1200 and 1300
    • Frame EF00 – Shelves 2100, 2200, and 2300
    • Frame EF01 – Shelves 3100, 3200, and 3300
    • Frame EF02 – Shelves 4100, 4200, and 4300
    • Frame EF03 – Shelves 5100, 5200, and 5300
    • Frame EF04 – Shelf 6100
    Shelf 1100 is the Control Shelf and is in Frame CF00. Shelf 1100 cannot be removed.
    Perform the Removing an Entry from the Frame Power Alarm Threshold Table procedure to remove the frame from the frame power alarm threshold table.
    If the frame containing the shelf being removed in this procedure is not shown in the rtrv-frm-pwr output, go to step 5.
  5. Remove the shelf from the database using the dlt-shlf command.
    For this example, enter this command.
    dlt-shlf:loc=2100
    When this command has successfully completed, this message should appear.
    DLT-SHLF: MASP A - COMPLTD
  6. Verify the changes with the rtrv-shlf command and specify the location of the shelf.
    rtrv-shlf:loc=2100
    SHELF DISPLAY LOCATION=1200
    FRAME SHELF        TYPE
    This shelf is UNEQUIPPED in the database.
  7. Back up the new changes using the chg-db:action=backup:dest=fixedcommand.
    These messages should appear, the active Maintenance and Administration Subsystem Processor (MASP) appears first.
    BACKUP (FIXED) : MASP A - Backup starts on active MASP.
    BACKUP (FIXED) : MASP A - Backup on active MASP to fixed disk complete.
    BACKUP (FIXED) : MASP A - Backup starts on standby MASP.
    BACKUP (FIXED) : MASP A - Backup on standby MASP to fixed disk complete.
Figure 4-14 Removing a Shelf
