| Oracle® Communications Diameter Signaling Router Policy and Charging Application Release 8.4 F12292 |
![]() Previous |
![]() Next |
Table 5-38 describes the elements on the screen. The elements can be configured and viewed on the NOAM, and only viewed on the SOAM. Data Input Notes apply to the Insert and Edit screens; the View screen is read-only.
The element labels are the same for each input field set, but some serve different purposes and have different values. These distinctions are noted in the table.
Table 5-38 Alarm Settings Elements
| Elements (* indicates required field) | Description | Data Input Notes |
| DSR Application Ingress Message Rate | ||
| * Alarm Name | This alarm is raised when average Policy and Charging ingress messages rate exceeds the configured threshold. The thresholds are based on the engineered system value for Ingress Message Capacity. |
Format: Non-editable text box Range: DSR Application Ingress Message Rate |
| * Critical Alarm Threshold (Percent) | The Policy and Charging ingress message rate threshold for this alarm to be raised as Critical. The threshold is a percentage of the Ingress Capacity Capability. |
Format: Text box Range: 100-200 Default: 160 |
| Suppress Critical | Controls whether this alarm is raised as Critical. |
Format: Check box Range: Unchecked (No) or Checked (Yes) Default: Unchecked (No) |
| * Major Alarm Threshold (Percent) | The Policy and Charging ingress message rate threshold for this alarm to be raised as Major. The threshold is a percentage of the Ingress Capacity Capability. |
Format: Text box Range: 100-200 Default: 140 |
| Suppress Major | Controls whether this alarm is raised as Major. |
| * Minor Alarm Threshold (Percent) | The Policy and Charging ingress message rate threshold for this alarm to be raised as Minor. The threshold is a percentage of the Ingress Capacity Capability. |
Format: Text box Range: 100-200 Default: 110 |
| Suppress Minor | Controls whether this alarm is raised as Minor. |
| SBR Sessions Threshold Exceeded | ||
| * Alarm Name | This alarm is raised when the number of concurrent Policy and Online Charging SBR sessions exceeds the configured threshold. |
Format: Non-editable text box Range: Policy SBR Sessions Threshold Exceeded |
| * Critical Alarm Threshold (Percent) | The concurrent sessions threshold for this alarm to be raised as Critical. The threshold is a percentage of the Maximum SBR Sessions. |
Format: Text box Range: 1-99 Default: 95 |
| * Major Alarm Threshold (Percent) | The concurrent sessions threshold for this alarm to be raised as Major. The threshold is a percentage of the Maximum SBR Sessions. |
Format: Text box Range: 1-99 Default: 90 |
| * Minor Alarm Threshold (Percent) | The concurrent sessions threshold for this alarm to be raised as Minor. The threshold is a percentage of the Maximum SBR Sessions. |
Format: Text box Range: 1-99 Default: 80 |
| SBR Bindings Threshold Exceeded | ||
| * Alarm Name | This alarm is raised when the number of concurrent Policy SBR bindings exceeds the configured threshold. |
Format: Non-editable text box Range: Policy SBR Bindings Threshold Exceeded |
| * Critical Alarm Threshold (Percent) | The concurrent bindings threshold for this alarm to be raised as Critical. The threshold is a percentage of the Maximum Policy SBR Bindings. |
| * Major Alarm Threshold (Percent) | The concurrent bindings threshold for this alarm to be raised as Major. The threshold is a percentage of the Maximum Policy SBR Bindings. |
| * Minor Alarm Threshold (Percent) | Te concurrent bindings threshold for this alarm to be raised as Minor. The threshold is a percentage of the Maximum Policy SBR Bindings. |
