| Oracle® Communications Diameter Signaling Router Policy and Charging Application Release 8.4 F12292 |
![]() Previous |
![]() Next |
Table 5-20 describes the elements on the screen.
Table 5-20 PCRF Sub-Pool Selection Rules Elements
| Fields (* indicates required field) | Description | Data Input Notes |
| * PCRF Sub-Pool Selection Rule Name | A name that uniquely identifies the PCRF Sub-Pool Selection Rule. |
Format: Text box; string 1-32 characters, must start with an upper or lower case letter, and can contain digits and underscores; maximum number of Sub-Pool Selection Rules is of 70 Default: N/A Range: Valid name |
| * Priority |
A priority value. A low value indicates a higher priority. Note: The priority value is used to break ties when more than one PCRF Sub-Pool Selection Rule matches a given binding-capable session initiation request. Multiple rules can match a request when more than one rule using a Starts With or Ends With condition exists. |
Format: Text box Default: 50 Range: 1-99, inclusive |
| * PCRF Pool Name |
The name of the PCRF Pool for which a Sub-Pool is being defined. A dropdown menu contains the names of all available PCRF Pools. The PCRF Pool does not need to have any APN mapped to it when this PCRF Sub-Pool Selection Rule is created. |
Format: Dropdown menu Default: N/A Range: Configured PCRF Pools that have not been specified as PCRF Sub-Pool Names |
| Conditions | A condition allows for configuration of a value to be compared to a given Diameter AVP using the specified operator. The only condition currently supported for PCRF Sub-Pool Selection Rules is for the Origin-Host AVP. The value field allows you to enter a string to be compared to the Origin-Host using the operator. |
Format: Dropdown menu and Text box Default: N/A Range: Equals, Starts With, and Ends With. |
| * PCRF Sub-Pool Name | The PCRF Sub-Pool that is to be used for Gx and Gxx session initiation request messages matching this Rule. |
Format: Dropdown menu Default: N/A Range: Assigned PCRF Sub-Pool Name |
| Last Updated |
This read-only field displays the date and time that this rule was created, or the last time the rule was changed, whichever is most recent. This field records the time and date of changes that may affect routing of binding capable session initiation requests. This date and time can be compared against binding creation times when troubleshooting using . |
Format: Text box (read-only) |
