| Oracle® Communications Diameter Signaling Router Policy and Charging Application Release 8.4 F12292 |
![]() Previous |
![]() Next |
Table 5-15 describes the elements on the screen. Data Input Notes apply to the Insert and Edit screens; the View screen is read-only.
Table 5-15 Policy Clients Elements
| Elements (* indicates required field) | Description | Data Input Notes |
| * Policy Client Peer Node Name |
The name of a configured Diameter Peer Node that identifies a Policy Client Peer Node. Selecting a Policy Client Peer Node name (blue hyperlink) displays the screen where Diameter Peer Nodes are filtered by the Policy Client Peer Node Name. |
Format: Pulldown list Note: The Policy Client Peer Node Name cannot be changed on the Policy Clients [Edit] screen. Range: Configured Diameter Peer Nodes |
| Topology Hiding Enabled | A read-only check box with default checked to indicate the Topology Hiding for the policy client peer node being enabled. It is the only option currently supported. |
Format: Check box Range: N/A (Read Only) |
| Comments | An optional comment that describes the Policy Client Peer Node. |
Format: Text box Range 0-64 characters |
