| Oracle® Communications Diameter Signaling Router Policy and Charging Application Release 8.4 F12292 |
![]() Previous |
![]() Next |
Table 5-13 describes the elements on the screen.
Table 5-13 Binding Key Priority Elements
| Field (* indicates a requried field) | Description | Data Input Notes |
| * Binding Key Type |
The Binding Key Type which is assigned to a Binding Key Priority. GUID-7C4F863F-9E67-4B6C-89EE-B44E01292AF6The first row is Priority 1 and the corresponding Binding Key Type is IMSI. This row is read-only. |
Format: Pulldown list Range: MSISDN, IPv4, or IPv6 for Priority 2, 3, and 4 Default: -Select- (No Binding Key Type selected) |
