| Oracle® Communications Diameter Signaling Router Policy and Charging Application Release 8.4 F12292 |
![]() Previous |
![]() Next |
Table 5-24 describes the elements on the screens. Data Input Notes apply to the Error Codes [Edit] screen; the View screen is read-only.
The Error Codes define the Result Codes to be returned for various Policy and Charging Error Conditions. Each Error Condition will return the Result Code configured for each applicable Diameter interface.
Table 5-23 indicates the Diameter interfaces that are supported for each Error Code.
The default Result Code is 3002-DIAMETER_UNABLE_TO_DELIVER.
Table 5-23 Interfaces Supported for Each Error Code
| Error Code | Result Code | Vendor ID |
| PCA Unavailable Or Degraded | Gx/Gxx, Gx-Prime, Rx, S9, Gy/Ro | Gx/Gxx, Gx-Prime, Rx, S9, Gy/Ro |
| PCA Functionality Unavailable or Disabled | Gx/Gxx, Rx, S9, Gx-Prime, Gy/Ro | Gx/Gxx, Rx, S9, Gx-Prime, Gy/Ro |
| Binding Not Found | Rx, Gx-Prime | Rx, Gx-Prime |
| Unable To Route | Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro | Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro |
| SBR Error | Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro | Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro |
| No Usable Keys In Binding Dependent Message | Rx,Gx-Prime | Rx,Gx-Prime |
| Session Not Found | Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro | Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro |
| Missing or Unconfigured APN | Gx/Gxx, S9 | Gx/Gxx, S9 |
Table 5-24 Error Codes Elements
| Fields (* indicates required field) | Description | Data Input Notes |
| * Error Condition | The name of the selected Policy and Charging Error Condition. | View only; cannot be edited |
| * Gx/Gxx, Result Code | The Result Code to be returned on the Gx and Gxx interfaces |
Format: Text box Range: 1-9999 Default: 3002 |
| Gx/Gxx Vendor ID |
The Vendor ID that corresponds with the Gx and Gxx interfaces. The Vendor ID --- means the RFC standard error code will be sent. |
Format: Text box Range: 1-4294967295 |
| * Rx Result Code | The Result Code to be returned to the Rx interface. |
| Rx Vendor ID |
The Vendor ID that corresponds with the Rx interface. The Vendor ID --- means the RFC standard error code will be sent. |
| * S9 Result Code | The Result Code to be returned to the S9 interface. |
| S9 Vendor ID |
The Vendor ID that corresponds the S9 interface. The Vendor ID --- means the RFC standard error code will be sent. |
| * Gx-Prime Result Code | The Result Code to be returned on the Gx-Prime interface |
Format: Text Box Range: 1-9999 Default: 3002 |
| Gx-Prime Vendor ID |
The Vendor ID that corresponds with the Gx-Prime interface. The Vendor ID --- means the RFC standard error code will be sent. |
Format: Text Box Range: 1-4294967295 |
| * Gy/Ro Result Code | The Result code to be returned on the Gy/Ro interface. |
Format: Text Box Range: 1-9999 |
| Gy/Ro Vendor ID | The Vendor ID that corresponds with the experimental code for the Gy/Ro interface. |
