Go to primary content
Oracle® Communications Diameter Signaling Router Policy and Charging Application
Release 8.4
F12292
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Error Codes elements
Table 5-24 describes the elements on the Policy and Charging > Configuration > Error Codes screens. Data Input Notes apply to the Error Codes [Edit] screen; the View screen is read-only.
The Error Codes define the Result Codes to be returned for various Policy and Charging Error Conditions. Each Error Condition will return the Result Code configured for each applicable Diameter interface.
Table 5-23 indicates the Diameter interfaces that are supported for each Error Code.
The default Result Code is 3002-DIAMETER_UNABLE_TO_DELIVER.
Table 5-23 Interfaces Supported for Each Error Code
Error Code Result Code Vendor ID
PCA Unavailable Or Degraded Gx/Gxx, Gx-Prime, Rx, S9, Gy/Ro Gx/Gxx, Gx-Prime, Rx, S9, Gy/Ro
PCA Functionality Unavailable or Disabled Gx/Gxx, Rx, S9, Gx-Prime, Gy/Ro Gx/Gxx, Rx, S9, Gx-Prime, Gy/Ro
Binding Not Found Rx, Gx-Prime Rx, Gx-Prime
Unable To Route Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro
SBR Error Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro
No Usable Keys In Binding Dependent Message Rx,Gx-Prime Rx,Gx-Prime
Session Not Found Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro Gx/Gxx,Gx-Prime, Rx, S9, Gy/Ro
Missing or Unconfigured APN Gx/Gxx, S9 Gx/Gxx, S9
Table 5-24 Error Codes Elements
Fields (* indicates required field) Description Data Input Notes
* Error Condition The name of the selected Policy and Charging Error Condition. View only; cannot be edited
* Gx/Gxx, Result Code The Result Code to be returned on the Gx and Gxx interfaces
Format: Text box
Range: 1-9999
Default: 3002
Gx/Gxx Vendor ID
The Vendor ID that corresponds with the Gx and Gxx interfaces.
The Vendor ID --- means the RFC standard error code will be sent.
Format: Text box
Range: 1-4294967295
* Rx Result Code The Result Code to be returned to the Rx interface.
Format: Text box
Range: 1-9999
Default: 3002
Rx Vendor ID
The Vendor ID that corresponds with the Rx interface.
Format: Text box
Range: 1-4294967295
* S9 Result Code The Result Code to be returned to the S9 interface.
Format: Text box
Range: 1-9999
Default: 3002
S9 Vendor ID
The Vendor ID that corresponds the S9 interface.
Format: Text box
Range: 1-4294967295
* Gx-Prime Result Code The Result Code to be returned on the Gx-Prime interface
Format: Text Box
Range: 1-9999
Default: 3002
Gx-Prime Vendor ID
The Vendor ID that corresponds with the Gx-Prime interface.
Format: Text Box
Range: 1-4294967295
* Gy/Ro Result Code The Result code to be returned on the Gy/Ro interface.
Format: Text Box
Range: 1-9999
Gy/Ro Vendor ID The Vendor ID that corresponds with the experimental code for the Gy/Ro interface.
Format: Text Box
Range: 1-4294967295
