| Oracle® Communications Diameter Signaling Router Roaming Steering Release 8.4 F12306 |
![]() Previous |
![]() Next |
Before you can configure SoR as a DCA Framework application, DCA Framework must be activated on the NO. See DCA Feature Activation.
Following DCA Framework activation, individual applications are in the disabled state. While disabled, no diameter traffic is delivered to SoR.
You now need to enable SoR. Perform this task from the page from the SO. See Diameter User's Guide for details.
Production and Trial functions are unavailable, and SoR's operational status is unavailable until you configure SoR.
