Go to primary content
Oracle® Communications Diameter Signaling Router Roaming Steering
Release 8.4
F12306
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Activating SoR
Use this task to activate SoR.
See DCA Feature Activation for detailed information.
  1. Check that the DCA framework has already been activated. See DCA Feature Activation.
  2. Add an entry in the DsrApplication if it does not already exist.
  3. Add an entry in the DcaDalId table if it does not already exist.
  4. Enable visibility for the main menu DCA Framework > DCA Roaming Steering subtree.
    The SoR instance is added to the GUI menu.
