| Oracle® Communications Diameter Signaling Router Roaming Steering Release 8.4 F12306 |
![]() Previous |
![]() Next |
Use this task to deactivate SoR. You cannot deactivate SoR while a verison of the respective application is still in the Production and/or Trial state.
Before deactivation can take place, the DCA Framework application must be disabled on all MPs in the network.
See DCA Feature Activation for detailed information.
