Go to primary content
Oracle® Communications Diameter Signaling Router Roaming Steering
Release 8.4
F12306
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Enabling SoR
Use this task to enable SoR on the SO. You can also pause updates using this task.
  1. Navigate to Diameter > Maintenance > Applications.
  2. Select DCA_SOR.
  3. Click Enable.
    The SoR instance is added to the GUI menu.
