Go to primary content
Oracle® Communications Diameter Signaling Router Roaming Steering
Release 8.4
F12306
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Disabling SoR
Use this task to disable SoR on the SO.
  1. Navigate to Diameter > Maintenance > Applications.
  2. Select DCA_SOR.
  3. Click Disable.
    The SoR instance is removed from the GUI menu.
