| Oracle® Communications Diameter Signaling Router Roaming Steering Release 8.4 F12306 |
![]() Previous |
![]() Next |
Table 3-2 describes the fields in the Config_Params and SoR_Profile Database tables.
Table 3-2 Config_Params and SoR_ProfileDatabase Table Elements
| Field (* indicates a required field) | Description | Data Input Notes |
| * Table Name | Unique name of the table | Format: Valid characters are alphanumeric and underscore, and must contain at least one alpha and must not start with a digit. Range: 1 - 32 characters Default: NA |
| Description | An optional description of the table | Format: Text string Range: 1 - 255 characters Default: NA |
| Single row | Indicates whether or not the table must have a single row | Format: Checkbox Range: checked, unchecked Default: unchecked |
| Level | Sets the configuration level of the table (NO or SO) | Format: Option Range: NO or SO Default: NO |
| Table fields | ||
| *Field Name | Unique name of the Table field | Format: Valid characters are alphanumeric and underscore, and must contain at least one alpha and must not start with a digit Range: 1 - 32 characters Default: NA |
| Description | An optional description of the table | Format: Valid characters are alphanumeric and underscore, and must contain at least one alpha and must not start with a digit Range: 1 - 255 characters Default: NA |
| Unique | Indicates whether the table must be unique | Format: Checkbox Range: checked, unchecked Default: unchecked |
| Mandatory | Indicates whether the table must be s mandatory | Format: Checkbox Range: checked, unchecked Default: unchecked |
| * Data type | Sets the date type | Format: List Range: Integer, Float, UTF8String, OctetString, IP Address, IP/Netmask, DiameterURI, DiameterIdentity, Enummerated, Boolean
Default: NA |
| * Min Value | Minimum integer value | Format: Integer Range: 1 - 64 Default: NA |
| * Max Value | Maximum integer value | Format: Integer Range: 1 - 64 Default: NA |
| Default Value | Default value | Format: Integer Range: 1 - 64 Default: NA |
| Remove | Removes the table | Format: Button Range: NA Default: NA |
| Add | Adds a table | Format: Button Range: NA Default: NA |
