| Oracle® Communications Diameter Signaling Router Roaming Steering Release 8.4 F12306 |
![]() Previous |
![]() Next |
When receiving a ULR message, SoR determines whether the message should be accepted or rejected. Accepting a ULR means that the message is forwarded for further processing on the DSR MP and possibly later to the HSS. Rejecting a ULR sends back a ULA message.
Table 2-1 Message Accept or Reject Criteria
| Condition | Description |
| vMNO status | If the ULR is coming from a vPLMN that belongs to a vMNO with non-preferred status from some country, then the message should be accepted only if none of the preferred vMNOs for that country has not received its defined share of traffic yet. A ULR coming through a vPLMN belonging to a preferred vMNO is always accepted. |
| vMNO share | In case of non-preferred MNOs, whether a ULR should be accepted or not depends on the number of successful registrations already served by the vMNO. |
| Registration history | Subscribers re-registering after a successful registration through some vMNO should be allowed to register through the same vMNO again regardless whether this vMNO has received its share. Furthermore, the number of registration attempts must be limited so as not to prolong the registration period indefinitely. |
Table 2-2 Data Collected by the SoR Application
