5Setting Up Function Spaces, Sleeping Rooms, and Suites
This chapter describes how to set up function spaces, sleeping rooms, and suites. It includes the following topics:
About Function Space Administration
Function spaces represent the physical areas within a property that are used for group events such as sales meetings, training sessions, weddings, and so on. Typical function spaces include meeting rooms, banquet rooms, ballrooms, the foyer, and other defined areas on the property grounds. Function space can have many characteristics, but during the booking process, the most important characteristics include the following:
Setup style
Minimum and maximum capacity for each setup style
Physical area in square feet or square meters
Usable area in square feet or square meters
Other characteristics of the function space (ceiling height, cable TV availability, and so on) can also be significant when considering whether or not a function must occupy a specific room to meet customer requirements.
Specific space represents the function rooms that are physically located at a property. A specific space usually has a name, for example, the Golden Gate Salon. There are two types of specific space, indivisible space and configured space.
Roadmap for Setting Up Function Spaces, Sleeping Rooms, and Suites
This topic lists the procedures and processes that administrators typically perform to set up function spaces, sleeping rooms, and suites using Siebel Hospitality. Your company might follow a different process according to its business requirements.
To set up Hospitality function spaces, sleeping rooms, and suites, perform the following processes:
Process of Setting Up Function Spaces
This topic lists the procedures that administrators typically perform to set up function spaces with Siebel Hospitality. Your company might follow a different process according to its business requirements.
To set up function spaces, perform the following tasks:
This task is a step in Roadmap for Setting Up Function Spaces, Sleeping Rooms, and Suites.
Creating Indivisible Specific Spaces
An indivisible space is a function space that cannot be subdivided. Indivisible spaces are the basic components that a property offers for function space bookings. Examples are small salons, meeting rooms, and board rooms. Like any other function space, an indivisible space occupies a physical area and has capacity characteristics. Depending on the location in the property, indivisible space units can be grouped to form a larger, configured spaces.
This task is a step in Process of Setting Up Function Spaces.
To create an indivisible specific space
Navigate to the Property Administration screen, then the Properties view.
In the Properties list, query for the required property record.
Click the link in the Property Name field, and then click the Specific Space view tab.
In the Specific Space list, create a new record and complete the appropriate fields, as required.
Some fields are described in the following table.
Field Comments Name
The name of the specific space.
Physical Area
The physical area of the specific space.
Backup Required
Indicates whether the specific space requires a backup function space. For more information about backup function spaces, see Marking a Space or Category as Requiring Backup.
Type
The product type. The default value is Indivisible. You can drill down on the Type field to define the features of the Type in the Product Key Features view.
Description
The description of the specific space.
Display Sequence
The sequence in which the function space appears in the Function Space Diary.
Compact Sequence
The sequence in which the function space appears in the Compact Diary view. For more information about the Compact Diary, see Function Space Diary Views.
Revenue Category
The revenue category associated with the specific space. This field is automatically populated with the Revenue Category value that is associated with the selected Revenue Sub Category.
If specific spaces are not associated with revenue categories, then revenue rollup for the specific spaces does not occur.
The revenue subcategory associated with the specific space.
Revenue Parent Category
The revenue parent category associated with the specific space. This field is automatically populated with the Revenue Parent Category value that is associated with the selected Revenue Sub Category.
Usable Area
The default value is the value of the Physical Area field. Can be changed to be less than the Physical Area if necessary.
Effective Start Date
Effective End Date
The date on which this space is available for use and the date on which this space is no longer available for use.
When effective start and end dates are defined for function spaces, these function spaces appear ineffective in the Function Space Diary on dates outside the effective period.
Floor Plan
An image of the floor plan for the specific space.
Special Location
Select to designate this function space as a special location. A Special Location designation is property-specific and user defined. When selected, indicates that the function space is not usually used as function space; or that the function space is used, sold, and so on only under special circumstances.
For example, an indoor pool might be a special location because it is booked infrequently. As another example, consider an off-site location that is sold and serviced by a specific hotel. Company XYZ has a large meeting facility in its building. Hotel ABC regularly sells this meeting facility to customers and provides food services. However, to book this space, there might be special requirements, or Hotel ABC might want to note that the function space is off site.
Creating Configured Specific Spaces
A configured space is a grouping of indivisible space components. Examples are ballrooms, banquet rooms, and large salons. The components of a configured space must be physically contiguous, sharing at least one wall.
Before you can create configured space, you must create indivisible spaces as described in Creating Indivisible Specific Spaces.
To create a configured specific space
In the Properties list, query for the required property.
In the Specific Space list, create a new record, and complete the fields as described in Creating Indivisible Specific Spaces.
In the Components list, perform the following steps:
Click New.
In the Add Components dialog box, select an indivisible space.
Click OK.
The specific space type remains Indivisible (the default), until you add components. After you add specific space components, the Type field value of the parent specific space record is automatically updated to Configured.
Note: You cannot associate a specific space with itself. Also, a specific space can only be added once to a configured space. When you add a specific space as a component of a configured space, it is no longer available for selection in the Add Components dialog box.Repeat Step 5 of this procedure to select additional components to the configured space.
You must add at least two components for the space to be a configured space.
Setting Up Function Space Categories for a Property
A function space category is a group of specific spaces at a property with common characteristics, usually related to capacity. The groupings can consist of indivisible spaces and configured spaces. For example, you can define function space categories such as Small Meeting Room, Medium Meeting Room, and Large Meeting Room with corresponding specific spaces.
Setting up function space categories simplifies room bookings. During the booking process, customers typically do not care in which room a function is held, as long as sufficient capacity and square footage is guaranteed.
To create a function space category for a property
Click the link in the Property Name field, and then click the Category view tab.
In the Category list, create a new record and complete the fields.
The following table describes the fields.
Field Comments Name
The name of the function space category.
Backup Required
Indicates whether the category requires backup function spaces. For more information about backup function spaces, see Marking a Space or Category as Requiring Backup.
Physical Area
The physical area of the category.
Type
Read only. Specifies a value of Category or Suite. The default value is Category.
Revenue Category
The revenue category associated with the function space category. This field is automatically populated with the Revenue Category value that is associated with the selected Revenue Sub Category.
If function space categories are not associated with revenue categories, then revenue rollup for the function spaces does not occur.
The revenue subcategory associated with the function space category.
The revenue parent category associated with the function space category. This field is automatically populated with the Revenue Parent Category value that is associated with the selected Revenue Sub Category.
Compact Sequence
The sequence in which the category will appear in the Compact Diary view. For more information about the Compact Diary, see Function Space Diary Views.
Property Unit of Measure
Read only. Shows the unit of measure value specified for the property.
Effective End Date
The date on which this category is available for use, and the date on which this category is no longer available for use.
When effective start and end dates are defined for categories, these categories appear ineffective in the Function Space Diary on dates outside the effective period.
Some function spaces require a backup space in case the function space cannot be used when required. For example, a wedding party might request to have photographs taken in a garden, or might ask to use a beach attached to the hotel for a beach wedding. However, because these are outdoor events, they might be affected by weather conditions. In these cases, it might be necessary to indicate that the function space requires a backup space.
The backup space to be used instead of a specific space can be specified when a quote involving the specific space is generated. For more information about backup spaces, see Managing Functions That Require Backup Space.
You can mark individual specific spaces as requiring backup spaces, or you can mark all the spaces associated with a function space category as requiring backup spaces.
This topic contains the following topics:
Marking a Specific Space as Requiring Backup
To mark a specific space as requiring backup, follow this procedure.
In the Properties list, query for and select the required property record.
In the Specific Space list, select the required specific space, and then select the Back Up Required field.
Marking a Function Space Category as Requiring Backup
To mark a function space category as requiring backup, follow this procedure.
In the Categories list, select the required category, and then select the Back Up Required field.
Associating Specific Spaces with a Function Space Category
You can associate a specific space with one function space category.
To associate a specific space with a function space category
In the Category list, select the category.
Scroll down to the Specific Space view tab and create a new record.
Note: If the Back Up Required field of the category has been selected, then only those specific spaces whose Back Up Required fields are selected will be displayed.Select the specific space record and click OK.
Configuring the Do Not Move Flag
When booking function spaces, users can specify that the function cannot be moved afterwards by other users (except administrators). For example, in the Quotes screen, Functions view, the Do Not Move Flag check box can be selected by users to restrict the movement of the function. For more information on using the Do Not Move Flag check box, see Preventing Functions from Being Moved.
The administrator can control the effects of users selecting the Do Not Move Flag check box by configuring the appropriate field in Siebel Tools. To configure the Do Not Move Flag check box, perform the steps in the following procedure.
Log in to Siebel Tools as an administrator.
Lock the TNT SHM Function project for editing.
In the Object Explorer, navigate to Business Component.
Query for TNT SHM Function.
From the Siebel Tools menu, choose Tools, Business Component, and then the Field menu item.
Query for Is Do Not Move Read Only.
Change the value for the Calculated Value field to Y.
The default value for this field is N.
Depending on the value you set for the Is Do Not Move Read Only field in Siebel Tools, selecting the Do Not Move Flag check box in Siebel Hospitality results in the behaviors described in About the Do Not Move Flag Configuration Values.
Compile your changes and replace the Siebel Repository File (.srf).
Restart the Siebel Hospitality application.
The TNT SHM Function business component contains a field named Is Do Not Move Read Only. To control the behaviors of the Do Not Move Flag check box in the Siebel Hospitality user interface, you can set the value of this field as described in Configuring the Do Not Move Flag. The behaviors of the Do Not Move Flag check box in Siebel Hospitality for the different values of Is Do Not Move Read Only are described in the following table.
Table Do Not Move Flag Configuration Values
| Is Do Not Move Read Only setting | Do Not Move Flag behaviors |
True (Y) |
False (N) |
Defining Setup Style List Values
Before setup styles can be associated with a property, you must define setup styles in the List of Values (LOV) table. For more information about working with LOVs, see Siebel Applications Administration Guide.
To define setup style list values
Navigate to the Administration - Data screen, then the List of Values view.
In the List of Values list, query for records where the Type field value equals TNT_SHM_FSI_STYLE.
If the desired setup style has not yet been defined, perform the following steps.
Click Clear Cache.
Create a new record.
Set the Type field to TNT_SHM_FSI_STYLE.
Complete the other fields, as required.
Associating Setup Styles and Packages with Properties
You can associate predefined setup styles and packages with properties. For more information about creating property-specific menus and packages, see Setting Up Property-Specific Menus and Packages .
To associate a setup style and a package with a property
Click the link in the Property Name field, and then click the Property Style view tab.
In the Property Style list, create a new record, and complete the fields as required.
Field Comments Setup Style
Select a predefined setup style.
Display Name
Enter a name to be displayed for this setup style in the Siebel Hospitality user interface.
Package
Associate a property-specific or common product with the setup style. The product, which might be simple or customizable, must have a Product Type value of Setup Style.
Associating Setup Styles with Function Space Categories
You can associate setup styles with function space categories.
To associate a setup style with a function space category
In the Category list, select the category, and then scroll down and click the Setup Style view tab.
In the Setup Style list, create a new record and select a setup style to associate with this category.
Note: If a setup style has an associated package, and that setup style is associated with the function space category, then the package is also associated with the function space category.
Optimizing Setup Styles for Specific Spaces
The setup styles associated with function space categories are automatically associated with the specific spaces that are included in these categories, if setup styles do not already exist. You can adjust the setup style information at the specific-space level to address the characteristics of a particular specific space.
To optimize a setup style for a specific space
In the Specific Space list, select a record, and then scroll down and click the Setup Style view tab.
Update each setup style record as required.
Process of Setting Up Sleeping Rooms
You can define sleeping rooms for a property. One or more generic sleeping room types can be mapped to one or more property-specific sleeping room types. You can assign a percentage to each mapped property-specific sleeping room type to specify how many rooms of each type to reserve.
Additionally, one or more property-specific sleeping room types can be mapped to a run of house (ROH) sleeping room type. For more information about ROH sleeping rooms, see About Run of House Room Types.
For use case examples of sleeping room mapping, see Scenarios for Mapping Sleeping Rooms.
This topic lists the procedures that administrators typically perform to set up sleeping rooms with Siebel Hospitality. Your company might follow a different process according to its business requirements.
To set up sleeping rooms, perform the following tasks:
Creating Sleeping Room Records
To create sleeping room records, follow this procedure.
This task is a step in Process of Setting Up Sleeping Rooms.
Click the link in the Property Name field, and then click the Sleeping Rooms view tab.
To create a property-specific sleeping room record, click the Property Specific Sleeping Rooms link after the Sleeping Rooms view tab.
In the Sleeping Rooms list, create a record and complete the fields.
Field Comments Capacity
The room capacity. The number of sleeping rooms of that type in the hotel.
Note: If the Type field value is Sleeping Room or Suite, then Capacity is user-defined and is greater than or equal to 0. If the Type field value is ROH Sleeping Room, then Capacity is automatically set to 0, and you cannot enter a quantity greater than 0 in this field.Description
A description of the sleeping room.
Name
A descriptive label for the sleeping room. Click the link in the Name field to navigate to the Product Administration screen, Products view.
Product Line
If defined, the product line associated with the sleeping room. Click the link in the Product Line field to navigate to the Product Administration screen, Product Lines view.
Room CRS Code
The Central Reservation System code for the sleeping room.
Type
The sleeping room type. Options are ROH Sleeping Room, Sleeping Room, and Suite.
The date on which this sleeping room is available for use.
Effective End Date
The date on which this sleeping room is no longer available for use.
Select Sleeping Rooms, or select another revenue subcategory to associate with this sleeping room. Through the revenue subcategory, the sleeping room is associated with a charge code, which in turn is associated with taxes and service charges. For more information, see About Hospitality Charge Codes, Taxes, and Service Charges.
Read only. Parent revenue category for this sleeping room. Populated when you complete the Revenue Sub Category field. If you select Sleeping Rooms in the Revenue Sub Category field, then by default, this field displays Sleeping Rooms as the parent revenue category.
Revenue Category
Read only. Revenue category for this sleeping room. Populated when you complete the Revenue Sub Category field. If you select Sleeping Rooms in the Revenue Sub Category field, then by default, this field displays Sleeping Rooms as the revenue category.
Mapping a Generic Room Type to Property-Specific Room Types
After generic sleeping room types are created, you can map the property-specific room sleeping room types to the generic sleeping room types. This mapping facilitates the conversion of generic room block items during the create quote process. This procedure assumes that the appropriate room types for the property have already been created.
To map a generic sleeping room type to property-specific sleeping room types, follow this procedure.
To map a generic room type to property-specific room types
Click the Map Sleeping Rooms link.
In the Generic Sleeping Room list, select a generic sleeping room type.
In the Sleeping Room list, associate one or more property-specific sleeping room types with the selected generic sleeping room type.
In the property-specific sleeping room type record, enter a value in the Percentage to Sell field. This value specifies the percentage of each specific sleeping room type to reserve for a single generic sleeping room type.
For example, suppose a generic sleeping room type named Generic Standard is mapped to two property-specific room types named Standard Smoking and Standard Non Smoking, with Percentage to Sell values of 25 percent and 75 percent, respectively. If a customer requests 100 Generic Standard sleeping rooms, the quote will reserve 25 rooms for Standard Smoking and 75 rooms for Standard Non Smoking.
Note: If a generic sleeping room is mapped to multiple property-specific sleeping room types, the sum of the Percentage to Sell values must equal 100 percent. If a generic sleeping room is mapped to a single property-specific sleeping room type, the Percentage to Sell value must be 100 percent.
Mapping a Run of House Room Type to Property-Specific Room Types
After property-specific sleeping room types are created, you can map run of house (ROH) sleeping room types to other property-specific sleeping room types. This allows users flexibility in assigning rooms to groups with nonspecific room requirements. This procedure assumes that property-specific room types for the property, including ROH room types, have already been created.
A property can have multiple ROH room types. A property-specific room type can only be assigned to one ROH room type.
To map a run of house (ROH) sleeping room type to one or more property-specific sleeping room types, follow this procedure.
To map a run of house room type to property-specific room types
Click the Map ROH Rooms link.
In the ROH Sleeping Rooms list, select a run of house room type record.
In the Sleeping Rooms list, associate one or more property-specific sleeping rooms with the selected ROH room.
Note: You can only associate a property-specific room type with one ROH room type.
Setting User Properties for Sleeping Room Mapping
You can set user properties to modify or enhance the Sleeping Room Mapping views in Siebel Hospitality. For more information about these user properties, see User Properties for Sleeping Room Mapping.
This topic gives the following examples of how sleeping room mapping might be used. You might use sleeping room mapping differently, depending on your business model.
This topic includes the following scenarios:
Mapping Each Property-Specific Room Type to One Generic Room Type
A hotel uses the mapping shown in the following table.
Table Each Property-Specific Room Mapped to One Generic Room
| Generic Room Type | Property Specific Room Type | Distribution Percentage |
Generic Standard |
King City View |
75 percent |
Double City View |
25 percent |
Generic Deluxe |
King Ocean View |
50 percent |
Double Ocean View |
50 percent |
If a customer requests 50 Generic Standard rooms and 100 Standard Deluxe rooms, the mapping returns the quote as shown in the following table.
Table Property-Specific Room Mapping in Quote
| Property Specific Room Type | Distribution Percentage | Number of Rooms | Rounding, if Applicable |
King City View |
75 percent of 50 rooms |
37.5 |
37 |
Double City View |
25 percent of 50 rooms |
12.5 |
13 |
King Ocean View |
50 percent of 100 rooms |
50 |
50 |
Double Ocean View |
50 |
50 |
Mapping a Property-Specific Room Type to Two Generic Room Types
A different hotel uses the mapping shown in the following table.
Table Property-Specific Room Mapped to Two Generic Rooms
Generic Standard |
King City View |
75 percent |
Double City View |
25 percent |
Generic Deluxe |
Double City View |
25 percent |
King Ocean View |
25 percent |
Double Ocean View |
50 percent |
Notice that the Double City View room type has been mapped to both Generic Room types. If a customer requests 50 Generic Standard rooms and 100 Generic Deluxe rooms, the mapping returns the quote as shown in the following table.
King City View |
37.5 |
37 |
Double City View |
50 percent of 25 rooms |
12.5 |
13 |
Double City View |
25 percent of 100 rooms |
25 |
25 |
King Ocean View |
25 |
25 |
Double Ocean View |
50 |
50 |
Because the Double City View room type is mapped to both the Generic Standard and Generic Deluxe room types, the distribution totals are combined. The quote displays one count for the combined room type, as shown in the following table.
Table Property-Specific Room Mapping in Quote with Distributions Combined
King City View |
37.5 |
37 |
Double City View |
50 percent of 25 rooms plus 25 percent of 100 rooms |
13 plus 25 |
38 |
King Ocean View |
50 |
25 |
Double Ocean View |
50 |
50 |
Process of Setting Up Suites
A suite in the hospitality industry is a type of sleeping room that can be used either as a sleeping room or as a function space. This topic lists the procedures that administrators typically perform to set up suites with Siebel Hospitality. Your company might follow a different process according to its business requirements.
To set up suites, perform the following tasks:
Setting Up Indivisible Specific Space Suites
The process of creating indivisible specific space suites is similar to the process for setting up indivisible specific spaces.
This task is a step in Process of Setting Up Suites.
To set up an indivisible specific space suite
Click the link in the Property Name field and then click the Specific Space view tab.
In the Specific Space list, create a new record and select the Suite check box.
For more information about the fields on the Property Administration screen, Specific Space view, see Creating Indivisible Specific Spaces.
Setting Up Configured Specific Space Suites
The process of creating configured specific space suites is similar to the process for setting up configured specific spaces.
To set up a configured specific space suite
Scroll down to the Components list and add a new record.
In the Add Component dialog box, select an indivisible specific suite space and click OK.
Repeat steps 6 and 7 of this procedure to select additional components.
For more information about adding components to a configured space, see Creating Configured Specific Spaces.
Setting Up a Suite Category
You can set up a category to group indivisible or configured specific space suites.
To set up a suite category
In the Category list, create a new category, and set the value in the Type field to Suite.
For more information about the fields on the Property Administration screen, Category view, see Setting Up Function Space Categories for a Property.
Associating Suite Specific Spaces with a Category
After creating the suite category, you can assign suite specific spaces to the category.
To associate suite-specific spaces with a category
In the Category list, select the suites category, and then scroll down to the Specific Space view tab.
In the Specific Space list, create a new record and select a suite-specific space.
Associating Setup Styles with Suite Categories
Assigning setup styles to suite categories is performed in the same way as assigning setup styles to other function space records. For more information, see Associating Setup Styles with Function Space Categories.
Setting Up Suite Administration
You can specify information for suites such as check-in times, check-out times, and revenue routing. Check-in and check-out information is used when booking suites as sleeping rooms.
To set up suite administration
Click the link in the Property Name field, and then click the Suite Administration view tab.
In the Suite Administration form, complete the fields as required.
The following table describes some of the fields.
Field Comments Check-in Time
The time when the guests can check in to the hotel when the suite is used as a sleeping room.
Check-out Time
The time when the guests have to check out of the hotel after sleeping in a suite.
Suite Room Rental
Select to count the suite rental as sleeping room revenue. Clear to count the suite rental as function space revenue.
