8Integrating Order Management with Third-Party Taxation Applications
This chapter describes how to set up and use Taxware applications. It contains the following topics:
About Third-Party Taxation Applications
Taxes are calculated on quotes as part of the eSales - Complete Checkout Process workflow. The Calculate Taxes step calls the Tax Calculator business service, which uses the Taxware Adapter Service business service to make a call to Taxware. The calculated sales tax from Taxware is copied to the quote. When the quote is turned into an order, the tax information is copied to the order.
Taxware Applications
Taxware International is a third-party service used to calculate the sales tax on orders. Siebel eSales is designed to work with the following Taxware modules:
Sales/Use. This module calculates sales and use taxes on purchases made in the United States and Canada. You can configure Sales/Use for product-specific taxation, using the Taxware Sales/Use Toolkit to map the product’s part number in the Siebel Business Application to its Tax Code in Sales/Use.
WORLDTAX. This module calculates sales and use taxes on purchases made outside the United States and Canada. You can configure WORLDTAX for product-specific taxation, using the Taxware WORLDTAX Toolkit to map the product’s part number in the Siebel Business Application to its Commodity/Service Code in WORLDTAX.
STEP. This module enables sales tax exemptions and works in conjunction with the Sales/Use module. A Siebel eSales customer is exempt from sales tax if the Siebel account with which the customer is associated has a tax certificate lodged in the STEP module. You implement this feature by entering the Siebel account ID (row ID) in the STEP Customer ID field on the STEP certificate entry form.
Universal Tax Link (UTL). UTL integrates external applications with the Sales/Use and WORLDTAX modules through a common gateway.
VERAZIP. Used for address verification, this module matches state, ZIP Code, city, and county information to make sure that an address is correct and complete, so that the Sales/Use Tax Application can locate the correct taxing jurisdiction.
For more information, see your Taxware documentation.
Installing Taxware Applications on Windows
Siebel Business Applications support the use of Taxware software on the Windows NT and Windows 2000 operating systems.
The tasks for installing Taxware applications on Windows are as follows:
Installing Sales/Use on Windows
Installing STEP on Windows
Installing UTL on Windows
Installing WORLDTAX on Windows
Setting up the Windows environment
For information on installing Taxware applications, see the Taxware documentation. For information on which versions of Taxware are supported by Siebel Business Applications, see Siebel System Requirements and Supported Platforms on Oracle Technology Network.
Setting Up Taxware Applications on Windows
After installation, you must do certain tasks, including setting an administrator user name and password, checking environment variables, loading files, and putting your company information into the application.
The tasks for setting up Taxware applications you installed on Windows are as follows:
Setting Up Sales/Use on Windows
Setting Up STEP on Windows
Setting Up WORLDTAX on Windows
For information on setting up Taxware applications, see your Taxware documentation.
Installing and Setting Up Taxware Applications on UNIX
Siebel Business Applications support the use of Taxware software on Oracle Solaris and AIX operating systems.
The tasks for installing and setting up Taxware applications on UNIX are as follows:
Installing Taxware Applications on UNIX
Setting Up Sales/Use on UNIX
Setting Up WORLDTAX on UNIX
For information on installing and setting up Taxware applications, see the Taxware documentation. For information on which versions of Taxware are supported by Siebel Business Applications, see Siebel System Requirements and Supported Platforms on Oracle Technology Network.
Enabling Tax Calculation
To use Taxware applications with Siebel eSales, you must set certain parameters for the eSales Object Manager component of the Siebel Server.
This topic contains the following subtopics:
Enabling Tax Calculation with the Sales/Use Tax System
To use the Sales/Use Tax System with Siebel eSales, you need to have company information defined in the Sales/Use Tax System Toolkit and on the Siebel Server.
To enable tax calculation with the Sales/Use Tax System
In the Sales/Use Tax System Toolkit, define your Company ID and Company Location, for example SIEBEL and SAN MATEO.
In your Siebel employee application, navigate to Administration - Server Configuration screen, Servers, Components, and then Parameters view.
In the Components list, select eSales Object Manager.
In the Component Parameters list, set values for the eSales Object Manager parameters listed in the table that follows.
Parameter Value Company ID for Sales Tax
Your company’s sales tax ID
Company Location for Sales Tax
Your company’s sales tax location
Enable Sales Tax
TRUE
Sales Tax Type
Taxware
Enabling Tax Calculation with WORLDTAX
To use the WORLDTAX application with Siebel eSales, you need to have company information defined in the WORLDTAX Toolkit and on the Siebel Server.
To enable tax calculation with WORLDTAX
In the WORLDTAX Toolkit, define your Company ID and Business Location, for example SIEBEL_FR and FR (France).
Enable Sales Tax
TRUE
Sales Tax Type
Taxware
In Siebel Tools, modify the user properties of the Tax - Configuration (Taxware) integration object, shown in the following table.
Integration Object User Property Value SHIPFROMCOUNTRY
ISO country code of the ship-from country (for example, FR for France)
WorldTaxInstalled
Y
SHIPFROMCOUNTRY can also be passed dynamically by modifying the Tax Integration (Siebel Quote Output) integration object and the data map to the Tax Integration (Taxware Input) integration object.
Taxing Customizable Products
Tax calculation is more complicated for customizable products because not all product components may need to be taxed. By default, for tax calculation, Siebel eSales submits the price of the product that is rolled up from its components. This means that if some of the component items do not need to be taxed, then the tax calculation is inaccurate.
You have the option of calculating tax at the component level for any customizable product. For information about setting up taxation at the component level, see Siebel Product Administration Guide.
Taxware Integration with Siebel eSales
Integrating Siebel eSales with third-party taxation applications involves two business services:
Tax Calculator. See Tax Calculator Business Service.
Taxware Adapter Service. See Taxware Adapter Business Service.
The Tax Calculator business service controls the process shown in the following.
Siebel EAI passes data from a quote record and the method name to a Siebel output integration object.
The Siebel Data Transformation Engine maps the Siebel output integration object to a Taxware input integration object.
The Siebel EAI XML Converter converts the Taxware input integration object into XML, using the CC XML Converter Business Service, and passes the XML data and method name to the Taxware Adapter Service.
The Taxware Adapter Service business service processes the data and uses Siebel eScript to call the Taxware API.
The Taxware Adapter Service gets the calculated sales tax from Taxware using the Taxware API.
The Taxware Adapter Service formats the sales tax data into an XML string.
The Siebel EAI XML Converter converts the XML into a Taxware output integration object.
The Siebel Data Transformation Engine maps the Taxware output integration object to a Siebel input integration object.
Siebel EAI updates the quote record with the calculated sales tax.
The Tax Calculator business service has one method, CalculateTax, with the following input arguments:
Siebel to Vendor Map Name
Vendor to Siebel Map Name
The Tax Calculator business service user properties are used to set the values given in the following table.
Table Tax Calculator Business Service User Properties
| Business Service User Property | Value |
Taxware:Adapter Business Service |
Taxware Adapter Service |
Taxware:Configuration Object |
Tax - Configuration (Taxware) |
Taxware:Input IntObject Name |
Tax Integration (Taxware Input) |
Taxware:Output IntObject Name |
Tax Integration (Taxware Output) |
For more information on business services, see Using Siebel Tools.
Integration Objects
Integration objects pass static or dynamic values to the business service. The architecture is modular in that you can create and use different integration objects for the same core business service. For example, while the preconfigured integration supports the Quote business component, you can create integration objects to calculate taxes directly on the Order business component.
The Tax Calculator business service uses the following integration objects:
Tax - Configuration (Taxware). Its user properties are shown in the following table.
Table Tax - Configuration (Taxware) User Properties
| Integration Object User Property | Value | Comments |
AUDFILEIND |
2 |
Audit File Indicator:
EXEMPTUSEFLAG |
Y |
Exemption Use Flag:
InputIntObjectName |
None |
OutputIntObjectName |
None |
SHIPFROMCOUNTRY |
US |
None |
SalesUseInstalled |
Y |
None |
VendorDll |
taxcommono |
Name of the shared library. |
WorldTaxInstalled |
N |
None |
Tax Integration (Siebel Quote). Its integration components are shown in the following table.
Table Tax Integration(Siebel QuoteIntegration Components)
| Integration Component | Fields |
Quote |
Account Id |
Currency Code |
Current Quote Ship To City |
Current Quote Ship To Country |
Current Quote Ship To Postal Code |
Current Quote Ship To State |
EAI Error Message |
Quote Number |
Tax Amount |
Quote Item |
Extended Line Total |
Extended Quantity |
Line Number |
Line Total |
Part Number |
Quantity |
Row Id |
Sales Product Flag |
Sales Service Flag |
Tax Amount |
Tax Subcomponent Flag |
Taxable |
Tax Integration (Taxware Input). Its integration components are shown in the following table.
Table Tax Integration(Taxware Input)Integration Components
| Integration Component | Fields That Pass Data from Siebel |
Invoice |
Currency Code |
Customer Id |
Document Number |
Invoice Number |
Ship To City |
Ship To Country |
Ship To State |
Invoice Item |
Line Number |
Line Total |
Part Number |
Quantity |
Ship to City |
Ship to Country |
Ship to Postal Code |
Ship to State |
See your Taxware documentation for more fields that can be passed. For information on how to pass more fields to Taxware, see Passing Data from Other Fields in the Siebel Database.
Tax Integration (Taxware Output). Its integration components are shown in the following table.
Table Tax Integration (Taxware Output) Integration Components
| Integration Component | Fields That Pass Data from Taxware | ||
Invoice |
City Tax Amount County Tax Amount Error Message Federal Tax Amount Invoice Number Secondary City Tax Amount Secondary County Tax Amount Secondary State Tax Amount State Tax Amount |
Invoice Item |
City Basis Amount |
City Completion Code |
City Tax Amount |
City Tax Rate |
County Basis Amount |
County Completion Code |
County Tax Amount |
County Tax Rate |
Federal Basis Amount |
Federal Completion Code |
Federal Tax Amount |
Federal Tax Rate |
General Completion Code |
General Completion Code Desc |
Line Number |
Secondary City Basis Amount |
Secondary City Completion Code |
Secondary City Tax Amount |
Secondary City Tax Rate |
Secondary County Basis Amount |
Secondary County Completion Code |
Secondary County Tax Amount |
Secondary County Tax Rate |
Secondary State Basis Amount |
Secondary State Completion Code |
Secondary State Tax Amount |
Secondary State Tax Rate |
State Tax Amount |
State Tax Rate |
For more information on integration objects, see Integration Platform Technologies: Siebel Enterprise Application Integration and Using Siebel Tools.
Data Maps
Data maps are used to map fields in one integration object to another integration object. You can view data maps by navigating to the Administration - Integration screen, and then the Data Maps view.
The data maps used in tax calculation, shown in the following table are specified in the call to the Tax Calculator business service.
Table Tax Calculation Data Maps
| Name | Source Object Name | Target Object Name |
TaxCalculation_QuoteToTaxware |
Tax Integration (Siebel Quote) |
TaxCalculation_TaxwareToQuote |
For more information on modifying integration objects and data maps, see Integration Platform Technologies: Siebel Enterprise Application Integration and Using Siebel Tools.
The Taxware Adapter Service business service:
Receives input from the Tax Calculator business service in XML format.
Passes the following information to Taxware:
Static information from the Tax - Configuration (Taxware) integration object
Dynamic information from the Tax Integration (Taxware Input) integration object
Receives information back from Taxware.
Passes XML data back to the Tax Calculator business service.
The Taxware Adapter Service consists of the following methods:
CalculateTax. This is the main method for calculating the tax. It converts the input XML string to a property set and calls the Taxware software to get the tax information as a property set. It then converts the tax information to an XML string as an output.
Initialize. This method uses the input property set to initialize the variables for the business service.
OpenClose. This method opens and closes files used by Taxware to calculate taxes.
Audit File
Taxware uses an Audit File to store transactional information for tax reporting purposes. The Audit File for Sales/Use is a text file that you can edit. There is a special editor for the WORLDTAX Audit File that marks transactions that have been altered.
When calculating taxes in Siebel eSales, set the audit file indicator (AUDFILEIND) to 2 (No Record) because the customer has not yet confirmed the order.
To write to the audit file, a separate call to Taxware must be made from the order. This setup requires creating Order integration objects and mappings to the Taxware integration objects.
You can set the value for AUDFILEIND by changing the value in the Tax - Configuration (Taxware) integration object user properties. For orders, you can set a separate default value in the data mapping.
Address Verification for Taxware
Completion codes are returned that indicate the status of the process running UTL if one of the following occurs:
The customer enters an improper city/state/zip combination.
In most cases the completion code appears, indicating that a jurisdiction error occurred, which means something was wrong with the zip/state combination.
The customer enters a city/state/zip combination that maps to more than one jurisdiction.
Taxware defaults to the most likely match and applies that rate for the transaction. The application generally uses the jurisdiction with the highest population, as rates for heavily populated areas are usually higher than those for areas with less population. However, the default rate used is not always the highest rate out of the possible matches.
Customizing Taxware Integration
You can customize Siebel eSales integration with Taxware. Some examples are passing more fields to Taxware, and performing tax calculations on data in other business components.
You can add data fields to those passed to Taxware. You must add the desired field to the appropriate integration objects and map the fields from your Siebel Business Application to Taxware, and from Taxware to your Siebel Business Application.
For more information on modifying integration objects, see Integration Platform Technologies: Siebel Enterprise Application Integration. For more information on modifying scripts, see Using Siebel Tools.
To add a data field
In Siebel Tools, add the field to the appropriate integration objects.
Activate the appropriate fields in Tax Integration (Taxware Input) and Tax Integration (Taxware Output) integration objects.
In your Siebel Business Application, navigate to the Integration Administration screen, and then the Data Map Editor.
Update the data map so that the appropriate Siebel data is passed to Taxware and an appropriate result is passed back to the Siebel database.
Passing Data from Fields Not in the Siebel Database
There are three ways to pass data from fields that do not exist in the Siebel database:
Add the field to the database, add it to the necessary integration object, and then update the data map.
Set an existing business service user property in the Tax Calculator business service, or create a new one, with a static value for all transactions. These values are read when the business service is initialized.
Any data passed dynamically using the integration objects will overwrite the value in the business service user property for that particular transaction.
Set a value for an integration object field by setting the value in the data map.
You cannot set a default value for an integration object user property because the Tax Calculator business service does not look for this value at initialization.
Calling the Tax Calculator Business Service from Other Places in Siebel eSales
You can call a business service from any of the following:
Button, if the applet the button is in is of the CSSBCBase class
Workflow
Script, either Siebel eScript or Siebel VB
For information on configuring applications and calling business services, see Using Siebel Tools.
To call the Tax Calculator business service from other places in Siebel eSales
Use the GetService() method to get an instance of the business service.
Use Service_InvokeMethod() to call a method of the business service.
Use SetProperty() to pass values for the business service method arguments that need to be set.
See Tax Calculator Business Service for the arguments of the CalculateTax method of the Tax Calculator Business Service.
Calling the Tax Calculator Business Service from Other Business Components
You can call the Tax Calculator business service from other business components besides Quote, for example Order. You can use the existing Tax Integration (Taxware Input) and Tax Integration (Taxware Output) integration objects for mapping.
To call the Tax Calculator business service from an order
Choose where to call the business service (button, workflow, or script).
In Siebel Tools, create integration objects for the Order business component to pass the correct data to the business service.
In your Siebel employee application, navigate to the Administration - Integration screen, and then the Data Map Editor.
Create integration object maps for the Order integration objects and the Taxware integration objects.
Handling Unicode Conversion Errors
Taxware applications use the ASCII codepage. Fields that are passed from Siebel eSales to Taxware applications are therefore converted from Unicode UTF-16 characters to ASCII characters.
For general information about Unicode support in Siebel Business Applications, see Siebel Global Deployment Guide.
Error Prevention During Codepage Conversion
If non-ASCII characters are entered into a required field, then an error is generated during the codepage conversion. The error is contained in the Error Message field of the integration object. The order will not be stopped by an error, but an employee will have to manually calculate the tax. It is therefore important to:
Generate guidance messages and error messages to prevent customers from entering non-ASCII characters in a required field. A list of required fields is given in the following table.
Only use lists of values that contain ASCII-compliant values.
Table Fields Required for the Taxware Integration
| Taxware Field | Siebel Field | Siebel Location | Required in Sales/Use | Required in WorldTax |
Company ID |
Company ID |
Configuration file |
Yes |
Yes |
Ship-From Country Code |
Ship From Country |
Business service integration object |
Yes |
Yes |
Destination/Ship-To Country Code |
Ship To Country |
Database |
Yes |
Yes |
POO Country Code |
From Taxware |
Yes |
Yes |
POA Country Code |
From Taxware (Defaulted to the setting in the Taxware Toolkit.) |
Yes |
Yes |
Line Item Amount |
Line Total |
Database |
Yes |
Yes |
State Code |
Ship To State |
Database |
Yes |
No |
Zip Code |
Database |
Yes |
No |
Document Number |
Quote # |
Database |
No |
Yes |
Tax Point |
Set in Adapter business service |
No |
Yes |
Transaction Type |
Set in Adapter business service (value of 1) |
No |
Yes |
Seller Registration |
From Taxware |
Set in the Taxware Toolkit. You can pass dynamic data by configuration. |
No |
Yes |
WT Code |
Siebel Sales Product Flag (set to 01) or Siebel Service Product Flag (set to 23) |
No |
Yes |
Commodity Code |
Part Number |
Database |
No |
Yes |
Primary Currency Code |
Currency Code |
Database |
No |
Yes |
Defining Required Fields in Codepage Conversion
You can define which fields that are passed to Taxware are required and whether a field is required for WorldTax, Sales/Use, or both applications.
To define required fields in codepage conversion
In Siebel Tools, from the View menu, select Options.
In the Development Tools Options dialog box, select Object Explorer.
Move Integration Object to the far pane of the dialog box and click OK.
Select the integration object Tax Integration (Taxware Input).
Select Integration Component Field from the Object Explorer.
To make a field required, check the External Required column.
To make a field required for:
Both WorldTax and Sales/User, leave the External DataType as String.
WorldTax only, change the External DataType to StringWT.
Sales/User only, change the External DataType to StringSU.
Configuring Error Messages in Codepage Conversion
You can perform the following configurations related to codepage errors:
You can configure the eSales - Complete Checkout Process workflow so that the order process stops when a codepage error is returned by Taxware. The default behavior is to allow the order process to continue.
You can configure the error messages displayed in the Quote Summary and Order Confirmation views of your employee application.
You can change the error messages that are displayed to customers on the Quote Form applet - Summary (eSales) applet and Order Form Applet - Confirmation (eSales) applet of your Siebel eSales Web site.
To configure error messages in codepage conversion
In Siebel Tools, select either the Quote Form - Summary (eSales) applet or Order Form Applet - Confirmation (eSales) applet.
Select Applet User Prop in the Object Explorer.
Replace the EAI Error Message text with the text of your choice in the user property that has the value LabelTaxNotCalculated.
