10Integrating with Oracle Policy Automation
This chapter describes how to integrate Siebel Order Management with Oracle Policy Automation to give product selection advice. It includes the following topics:
About Creating Product Advisors
You can integrate Oracle Policy Automation with Siebel Order Management to create a rule base that guides customers through purchasing decisions by:
  • Recommending products, services, or courses of action based on user needs.
  • Selecting and configuring products based on product features and user requirements.
Process of Setting Up Oracle Policy Automation to Create Product Advisors
To set up Oracle Policy Automation to create product advisors, the administrator performs the following steps:
  1. Integrating the Siebel Application with Oracle Policy Automation
  2. Creating the Oracle Policy Automation Rule Base
  3. Verifying the Integration
    You must integrate the Siebel application with Oracle Policy Automation by specifying a symbolic URL.
    To integrate the Siebel Application with Oracle Policy Administration
    1. In the Siebel application, navigate to Administration - Integration, then WI Symbolic URL List.
    2. In the Name field, query for AdvisorsRuleSet
    3. If it is not present create a new record with that name.
    4. Complete the necessary fields, as shown in the following table.
      Field Value
      URL
      http://<Server>:<Port>/web-determinations/ with OPA server and Port details
      For example: http://slc02vaa.us.oracle.com:7065/web-determinations
      Fixup Name
      InsideApplet
      SSO Disposition
      IFrame
    5. In the Symbolic URL Argument form (the child applet), complete the necessary fields, as shown in the following table.
      Field Value
      Name
      IFrame
      Required Argument
      TRUE
      Argument Type
      Command
      Argument Value
      iFrame width=750 height=500 frameBorder=On
      Note: Adjust the Adjust the width and height to suit your requirements for displaying the Advisor popups.
      Append Argument
      TRUE
      Sequence
      1
    6. Log out of the Siebel application, and then log in again.
      You must create Oracle Policy Automation rule bases that are needed to help with purchasing decisions. The rules that are needed depend on your business model and the products you sell.
      For more information creating rule bases, see the Oracle Policy Automation documentation library on Oracle Technology Network.
        After you have set up the integration and the rule bases, you can verify the integration.
        To verify the integration
        1. Navigate to the Sales Order or Quotes Screen, then to the Catalog View and the Get Advice view.
        2. Click the Advisors button.
          Note: Right-click this button if you want to open the OPA screen in a different browser window or tab, so you can continue to use the Siebel application without having to close the Advisor.
          What appears depends on how OPA was configured on the server and on what location on the server the URL points at. If you defined multiple of rule bases, it is best to display a list of Advisors, so the user can choose one of the rule bases you created. If you defined only one rule base, it is best to display that rule base directly, without requiring the user to select it from a list.
        3. If a list is displayed, click one of the Advisors in the list.
          An Advisor is displayed in the same popup window that the list was displayed in.
          Using Oracle Policy Automation Product Advisors
          After administrators have set up Oracle Policy Automation to create product advisors, users can access the rule bases to guide purchasing decisions.
          The procedure for the user to access the rule base is the same as the procedure that the administrator uses to verify the integration. For more information, see Verifying the Integration.
