8Operators for Building Condition Expressions
This section describes the operators that are available for building condition expressions specific to Siebel Personalization. It includes the following topics.
For more information on operators, see Using Siebel Tools.
Arithmetic Operators
The following table lists arithmetic operators.
See also Comparison Operators, Logical Operators, and Pattern Matching Operators.
Table Arithmetic Operators
Operator Description
Add
Subtract
Multiply
Divide
Power
The following table lists comparison operators.
See also Arithmetic Operators, Logical Operators, and Pattern Matching Operators.
Table Comparison Operators
Equal to a specific value.
Not equal to a specific value.
Greater than a specific value.
Less than a specific value.
Greater than or equal to a specific value.
Less than or equal to a specific value.
NOT. Used to exclude values.
IS NULL
Finds blank fields.
Using the = operator without any accompanying value does not give you the same results as IS NULL.
IS NOT NULL
Finds non-blank fields.
Logical Operators
The following table lists logical operators.
See also Arithmetic Operators, Comparison Operators, and Pattern Matching Operators.
Table Logical Operators
AND
All conditions connected by AND must be TRUE.
OR
At least one condition connected by OR must be TRUE.
NOT
The condition modified by NOT must be FALSE.
The following table lists pattern matching operators.
See also Arithmetic Operators, Comparison Operators, and Logical Operators.
Table Pattern Matching Operators
(asterisk) Wildcard for any number of characters before or after the value entered.
Used in combination with LIKE.
(question mark) Wildcard for a single character.
LIKE
Combine with a string and one or more wildcard characters to find all values with string.
For example: [Product Line] LIKE *enti?m* returns records where the Product Line field contains the string enti?m such as The Pentium I Line and Pentiums.
NOT LIKE
Combine with a string and one or more wildcard characters to find all values without string.
EXISTS
Finds a value from a multivalue group. EXISTS also finds values in any child of the MVG.
For example: EXISTS ([Product Component] = 4 Meg Ram) returns records in which attribute Product Component (an MVG) referred to is a child record with the value 4 Meg Ram.
