14Keywords Reference
Keywords Reference
This chapter defines the keywords that are available for Siebel Open UI keyword automation testing and describes how to use each keyword. This appendix contains the following topics:
Keywords Definition
Table Siebel Open UI Keyword Automation Testing - Keywords Definition
| Keyword Name | Description | Applies to Desktop? | Applies to Mobile? |
Performs actions on the Attachment Download Manager page in Siebel Mobile Application Framework (MAF). |
No |
Yes |
Clicks on a button control. |
Yes |
Yes |
Drills down on a link in a list applet, drills down on recently viewed links on the homepage, and shows more or less objects. |
Yes |
Yes |
Clicks the Sync button to navigate from offline to online and online to offline based on the user provided options. It also verifies the state of the application after the specified navigation. |
No |
Yes |
Clicks the top unread message in the notification list. |
Yes |
No |
Adds or removes columns in the list applet column (which is an option available in the applet menu). |
Yes |
Yes |
Compares a variable value with the expected value. |
Yes |
Yes |
Creates a new record in a list or form applet. |
Yes |
Yes |
Drags a record and drops it on a particular field. |
Yes |
Yes |
Captures a signature. |
Yes |
Yes |
Downloads (and exports) a file. |
Yes |
No |
Attaches or uploads (or imports) a file. |
Yes |
Yes |
Reads the value from the About Record pop-up window and stores the value in a user variable. |
Yes |
Yes |
Reads the value from the unitconfig.xml/batchconfig.xml file and stores the value in a user variable. |
Yes |
Yes |
Obtains the total number of records and stores the value in a user variable. |
Yes |
Yes |
Obtains the state of a specified object and stores the value in a user variable. |
Yes |
Yes |
Obtains the value of a specified object and stores the value in a user variable. |
Yes |
Yes |
Reads a value from an application level pop-up menu. |
Yes |
No |
Views and changes the default settings of a user profile. |
Yes |
Yes |
Navigates to a view that is available in the Threadbar link. |
Yes |
Yes |
Navigates to a specified view using the Tab view, Tree view, or Site Map links. |
Yes |
Yes |
Expands or collapsess a record in a hierarchical list applet, and shows the child items. |
Yes |
No |
Reads the XML request from a .xml file, posts the request to the server, and saves the XML response from the server. |
Yes |
No |
Enters a value into a specified field. |
Yes |
Yes |
Invokes a menu item from an applet-level menu in a list or form. |
Yes |
Yes |
Invokes a menu item from the application menu bar. |
Yes |
Yes |
Invokes an object in a specified field in a list or form applet. |
Yes |
Yes |
Starts the browser and logs in to an application with the provided username. |
Yes |
Yes |
Locks or unlocks a selected column. |
Yes |
Yes |
Logs out from an application. |
Yes |
Yes |
Performs the required action in the MAF Settings page in MAF applications. |
No |
Yes |
Selects one or more rows in a list applet. |
Yes |
Yes |
Queries an existing record from a list or form applet. |
Yes |
Yes |
Removes a record from the list in a multi-value group (MVG). |
Yes |
Yes |
Selects or clears a check box depending on the provided value (True or False). |
Yes |
Yes |
Select the specified record after querying the available records in an MVG. |
Yes |
Yes |
Queries and selects the first record from a drop-down list applet. |
Yes |
Yes |
Selects a value from the Predefined Drop-down Query (PDQ). |
Yes |
Yes |
Selects a value from a drop-down list in a list or form applet. |
Yes |
Yes |
Selects a radio button. |
Yes |
No |
Selects a record from a list applet. |
Yes |
Yes |
Selects a value from a toggle control in a list applet. |
Yes |
No |
Selects a value from the Visibility Filter drop-down list. |
Yes |
No |
Trigger a keyboard event. |
Yes |
Yes |
Calls the DateTime or Date pop-up calendars to specify the date and time. |
Yes |
Yes |
Sorts a selected column. |
Yes |
Yes |
Expands or collapses an explorer tree, and selects items from or shows items under an explorer tree. |
Yes |
No |
Verifies the lock status of a column. |
Yes |
Yes |
Verifies the order of records in a selected column. |
Yes |
Yes |
Verifies the error message for a string value. |
Yes |
Yes |
Performs image validation. |
Yes |
Yes |
Verifies the focus present on an applet, view, field, or row depending on the value provided (True or False). |
Yes |
Yes |
Counts the number of items in a drop-down list, auto selects using substring, and verifies the values in the drop-down list. |
Yes |
Yes |
Verifies the presence of an object or the UI name for an object. |
Yes |
Yes |
Verifies the row count in a list applet. |
Yes |
Yes |
Verifies the state of a specified field. |
Yes |
Yes |
Verifies whether the top read or unread message in the notification list appears or not. |
Yes |
Yes |
Verifies a field value by comparing it with a user variable. |
Yes |
Yes |
Keywords Description
This topic provides descriptions of each keyword that is supported for Siebel Open UI keyword automation testing.
Attachment Manager
You use the AttachmentManager keyword to perform actions in the Attachment Download Manager page in MAF applications.
Signature
The AttachmentManager keyword supports the following signature:
AttachmentManager(AppletRN, Name of the Entity|Name of the File Name, ...;DOWNLOAD/ DOWNLOADALL/REMOVE/CLOSE/TOP)
Desktop Examples
The AttachmentManager keyword does not apply to desktop applications.
Mobile Examples
The following table describes how to use the AttachmentManager keyword to perform actions in the Attachment Download Manager page in MAF applications (on mobile devices).
| Target Object | Inputs | Closing Action | Comments |
downloadMgrDiv |
AdminSalesTool|Zonall_Launch.zip,AdminSalesTool|ZonallPatientProfile.zip;DOWNLOAD |
Downloads the selected files. |
downloadMgrDiv |
AdminSalesTool|Zonall_Launch.zip,AdminSalesTool|ZonallPatientProfile.zip;DOWNLOADALL |
Downloads the all files. |
downloadMgrDiv |
AdminSalesTool|Zonall_Launch.zip,AdminSalesTool|ZonallPatientProfile.zip;REMOVE |
Removes the selected files. |
downloadMgrDiv |
AdminSalesTool|Zonall_Launch.zip;TOP |
Moves the file to the top position. |
downloadMgrDiv |
DivAdminSalesTool|Zonall_Launch.zip;Close |
Closes the AttachmentDownload Manager.
Note: Use close action with only one name or value pair.
ClickButton
You use the ClickButton keyword to click on a button control present in any list or form applet or in any multi-value group or drop-down applet, and to click Close (the X icon) to close a pop-up window.
Signature
The ClickButton keyword supports the following signature:
ClickButton(AppletRN|ButtonRN,OK/CANCEL/NULL)
Note the following about the ClickButton keyword signature:
If the action is to be performed on Tile applets, then the SelectRecordInListApplet keyword should be used before the Click button.
You must provide OK and Cancel options in case a Delete confirmation dialog box is expected.
You must provide NULL for other buttons, even if a pop-up window or dialog box is expected. Other keywords will carry out any subsequent action on the pop-up window or dialog box.
Desktop Examples
The following table describes how to use the ClickButton keyword to click on button controls in desktop applications.
Synergy Toolbar |
NULL |
Clicks the Delete Record button in a list applet and handles the button in the confirmation pop up. |
NULL|SiebTabViews |
NULL |
In SUI theme, invokes the L2 level links that appear when a button is clicked. |
SIS Account List Applet|NewQuery |
NULL |
SIS Account List Applet|DeleteRecord |
OK |
Clicks the Delete Record button in a list applet. |
SIS Account Entry Applet|GotoNextSet |
NULL |
Clicks the Go to Next Set button in a form applet. |
Product Pick Applet(Eligibility)| PickRecord |
NULL |
Clicks the drop-down list in a pop-up window. |
NULL|PickRecord |
NULL |
Clicks a button in a pop-up window. |
Close |
OK |
Clicks Close or X button in a pop-up window and then clicks OK. |
Close |
Cancel |
Clicks Close or X button in a pop-up window and then clicks Cancel. |
Mobile Examples
The following table describes how to use the ClickButton keyword to click on button controls in desktop mobile applications (on mobile devices).
SHCE Sales Contact List Applet - Mobile|DeleteRecord |
OK |
SHCE Sales Contact List Applet - Mobile|Create |
NULL |
Clicks the Create button in a list applet. |
Close |
OK |
NULL|NewQuery |
NULL |
ClickLink
You use the ClickLink keyword to drill down on links in a list applet, to drill down on recently viewed links on the homepage, and to show more or show less objects.
Signatures
The ClickLink keyword supports the following signatures:
ClickLink(AppletRN|FieldRN/ClassName/RowId|[RowNum],Value/Variable/NULL/ShowMore/ Show Less/Expand/Collapse)
ClickLink(AppletRN|@Var ,Value/Variable)
ClickLink(AppetRN|TimeslotRN ,NULL)
ClickLink(AppetRN|@FirstName+@LastName+TimeslotRN,NULL)
Desktop Examples
The following table describes how to use the ClickLink keyword to drill down on links in desktop applications.
ClickLinkAccount Contact List Applet|Last Name |
<Ramakrishna> |
Drills down on the Last Name value. For example, drills down on the last name value Ramakrishna. |
ClickLinkAppletRN|ClassName |
NULL |
Clicks on the link based on the Class Name. |
NULL|SiteMap |
NULL |
Clicks on the toolbar item (Site Map). |
Account Contact List Applet|Last Name|2 |
Pinas |
Drills down on the Last Name of the second record with the value provided in the inputs. |
SIS Account List Applet|ToggleListRowCount |
NULL |
Clicks the Show More link in the list applet. |
Show More |
Clicks the Show More link in the List applet. |
Show Less |
Clicks the Show Less link in the List applet. |
LS Pharma Inbox Applet|ButtonMaximizeApplet |
Expand |
Expands the list in the Home page. |
LS Pharma Inbox Applet|ButtonMinimizeApplet |
Collapse |
Collapses the list in the Home page. |
Contact Home Public and Private View Link List Applet|Name |
My Contacts |
Clicks the link of the recently viewed contacts screen (My Contacts). |
NULL|Save Query As Applet.SaveAs |
NULL |
Clicks the button link in the pop-up window. |
Account Home Public and Private View Link List Applet|2 |
All Accounts |
Click the frequently viewed links. |
Mobile Examples
The following table describes how to use the ClickLink keyword to drill down on links in mobile applications (on mobile devices).
SHCE Sales Contact List Applet - Mobile|Last Name|1 |
<last name> |
Drills down on the name value in the first row. |
SHCE Sales Contact List Applet - Mobile|Last Name |
<last name> |
Drills down on the name value. |
LS Home Page Calendar Applet-Mobile|@Var |
NULL |
Drills down on a call in the calendar applet. You can obtain the row Id of the record using GetAboutRecord keyword by navigating to the view. |
LS Home Page Calendar Applet-Mobile|slot-0-090000MikeAdlerDr. |
NULL |
Clicks the specified timeslot in the Calendar applet. |
LS Home Page Calendar Applet-Mobile|@AccountCall+slotCol-0-10:00 |
NULL |
Supports clicking on the dynamic Timeslot in the Calendar applet (Account call). |
LS Home Page Calendar Applet-Mobile|@FirstName+@LastName+@title+slotCol-0-10:00 |
NULL |
Supports clicking on the dynamic Timeslot in the Calendar Applet (Contact call). |
LS Home Page Calendar Applet-Mobile|@Accountname+@Date |
NULL |
Supports clicking on the dynamic activity in the Calendar applet. |
ClickSyncButton
Depending on user provided options, you use the ClickSyncButton keyword to click on the Sync button to switch from offline to online mode or from online to offline mode. The keyword also verifies the state of the application after the specified navigation.
Signature
The ClickSyncButton keyword supports the following signature:
ClickSyncButton(RnofSyncButton,RnofOfflineOptions;RnofStateoftheApplication)
Desktop Examples
The ClickSyncButton keyword does not apply to desktop applications.
Mobile Examples
The following table describes how to use the ClickSyncButton keyword to switch between online and offline modes in mobile applications (on mobile devices).
GoOffline |
NULL;Offline |
Clicks the Sync button and moves to offline mode. |
GoOffline |
uploadGoOnline;Online |
Clicks the Sync button and selects the option uploadGoOnline in offline mode. |
GoOffline |
syncStayOffline;Online |
Clicks the Sync button and selects the option syncStayOffline in offline mode. |
GoOffline |
uploadStayOffline;Online |
Clicks the Sync button and selects the option uploadStayOffline in offline mode. |
ClickTopNotification
You use the ClickTopNotification keyword to click and drill down on the top unread notification message in the notifications list. You also use the keyword to click the Mark All as Read option in the notification list, and then close the notification list.
Signature
The ClickTopNotification keyword supports the following signature:
ClickTopNotification(MessagebroadcastRN,Expectedmessage,Close/KeepOpen)
ClickTopNotication checks for notification messages for up to ten iterations (with an interval of one minute for each of the iterations).
Desktop Examples
The following table describes how to use the ClickTopNotification keyword to drill down on the top unread notification.
MsgBrdCstIcon |
Account_10142015_041155918 |
Close |
Clicks the top unread message in the notification list and closes the control. |
MsgBrdCstIcon |
Mark All As Read |
Close |
Clicks the Mark all as Read option in the notifications and closes the control. |
MsgBrdCstIcon |
Mark All As Read |
KeepOpen |
Clicks the Mark all as Read option in the notifications and keeps the control open. |
MsgBrdCstIcon |
NULL |
Close |
Closes the notification control. |
MsgBrdCstIcon |
KeepOpen |
Clicks the top unread message in the notifications and keeps the control open. |
Mobile Examples
The ClickTopNotification keyword does not apply to mobile applications.
ColumnsDisplayed
You use the ColumnsDisplayed keyword to specify the columns to appear in a list applet, and in what order. You use the keyword to move columns from the Available to the Selected list (or from the Selected to the Available list), and to move columns up and down so that the column order changes as required. The following actions are supported: Save, Reset, and Cancel.
Signature
The ColumnsDisplayed keyword supports the following signature:
ColumnsDisplayed(AppletRN|ColumnsDisplayedRN,Select:columnName1|columnName2|..; DeSelect:columnName1|columnName2|..;Order:columnName|Up/Down/Top/Bottom,RN (Save/ Cancel/Reset Defaults))
where:
The value in columnName must be used for desktop applications.
The display text in columnName must be used for mobile applications.
Desktop Examples
The following table describes how to use the ColumnsDisplayed keyword to move columns in desktop applications.
SIS Account List Applet|Columns Displayed (SWE) |
Select:Account Team;NULL;NULL |
Columns Displayed Popup Applet (SWE).ButtonSave |
Adds the Account Team column to the list applet. |
NULL;DeSelect:Account Team;NULL |
Hides the Account Team column to the list applet. |
Select:ALL;NULL;NULL |
Adds all columns to the list applet. |
NULL;DeSelect:ALL;NULL |
Hides all columns to the list applet. |
NULL;NULL;Order:Account Team|UP |
Orders the columns by moving one position left in the list applet. |
NULL;NULL;Order:Account Team|DOWN |
Orders the columns by moving one position right in the list applet. |
NULL;NULL;Order:Account Team|TOP |
Moves the column to the first position in the list applet. |
NULL;NULL;Order:Account Team|BOTTOM |
Moves the column to the last position in the list applet. |
NULL;NULL;NULL |
Columns Displayed Popup Applet (SWE).ButtonCancel |
Opens the ColumnDisplayed pop-up window and clicks Cancel. |
NULL;NULL;NULL |
Columns Displayed Popup Applet (SWE).ButtonReset |
Opens the ColumnDisplayed pop-up and clicks Reset. |
Move the column to the last position in the list applet and clicks Reset. |
Mobile Examples
The following table describes how to use the ColumnsDisplayed keyword to move columns in mobile applications (on mobile devices).
Moves the columns to the first position in the list applet. |
Moves the columns to the last position in the list applet. |
CompareValue
You use the CompareValue keyword to compare a variable value with the expected value. The expected value can be a variable or value.
Signature
The CompareValue keyword supports the following signature:
CompareValue(@Variable|Operator|value (or) @Variable)
Operator can be one of the following characters or values: = (equalsl), > (greater than), < (less than), <= (less than or equal to), >= (greater than or equal to), contains, startswith, endswith.
Desktop Examples
The following table describes how to use the CompareValue keyword to compare a variable value with the expected value for desktop applications.
@var1|>=|3.56 |
Verifies a variable value by comparing it with the expected value 3.56. |
@Var1|=|@Var2 |
Verifies a variable value by comparing it with the expected value. |
@Var|startswith|nc |
Verifies a variable value by comparing it with the expected value that starts with nc. |
@Var|endswith|nc |
Verifies a variable value by comparing it with the expected value that ends with nc. |
@Var|=|{[123]} |
@Var|=|"text123; |
"Verifies a variable value by comparing it with the expected value text123. |
Mobile Examples
The following table describes how to use the CompareValue keyword to compare a variable value with the expected value for mobile applications (on mobile devices).
@var1|>=|3.56 |
@Var1|=|@Var2 |
@Var|endswith|nc |
Verify a variable value by comparing it with the expected value that ends with nc. |
@Var|=|{[123]} |
@Var|=|"text123; |
CreateRecord
You use the CreateRecord keyword to create a new record by entering values into one or more fields in a list or form applet. The keyword fails in list applets if the sequence Id is automatically generated when a user tries to create a new record.
Signature
The CreateRecord keyword supports the following signature:
CreateRecord(AppletRN|Button(RN)|[RowNum],FieldRN(1..N)|Value(1...N) OR Variable,RN of Save record in AppletMenu)
Note the following about the CreateRecord keyword signature:
The row number is optional.
The keyword supports:
Unique values by adding the '$' symbol at the end of the text.
Date format like Today,Today+1,Today-1.
Variables like @var1, @var2 and numbers.
Desktop Examples
The following table describes how to use the CreateRecord keyword to create a new record in list and form applets in desktop applications.
Contact List Applet|NewRecord |
Last Name|last,First Name|first |
WriteRecord(SWE) |
Creates a record in the list applet. |
SIS Account List Applet|NewRecord |
Name|D$,Account Status|Red Customer |
WriteRecord(SWE) |
Contact Form Applet|NewRecord |
LastName|@var1,FirstName|first |
WriteRecord(SWE) |
Creates a record in the form applet. |
Contact List Applet|NewRecord|3 |
Last Name|@Variable |
WriteRecord(SWE) |
Creates a record in the third row in the list applet. |
Mobile Examples
The following table describes how to use the CreateRecord keyword to create a new record in list and form applets in mobile applications (on mobile devices).
SHCE Sales Opportunity Form Applet - Mobile|New |
Name|John$,Currency|USD,CloseDate|11|12|12 |
WriteRecord |
CG Account List Applet - Mobile|New |
Name|abc |
WriteRecord |
CG Account List Applet - Mobile|New|4 |
Name|abc |
WriteRecord |
Creates a record in the fourth row in the list applet. |
DragAndDrop
You use the DragAndDrop keyword to drag a record from an applet and drop it on a particular field.
Note the following about the DragAndDrop keyword signature:
The records must be visible in the screen.
In the mobile application, the keyword works only in landscape mode and both source and destination applets must be active.
Signatures
The DragAndDrop keyword supports the following signatures:
DragAndDrop (SourceAppletRN|NULL|Rowno, DestinationAppletRN|FieldRN)
DragAndDrop (SourceAppletRN|FieldRN, DestinationAppletRN|FieldRN)
Desktop Examples
The following table describes how to use the DragAndDrop keyword to drag a record from an applet and drop it on a specific field in desktop applications.
FINCORP Deal Account Pick Applet|NULL|3 |
Opportunity List Applet|Account |
Drags a record from an applet and drops it on a specific field. |
Opportunity List Applet|Primary Revenue Win Probability |
Swaps the columns in the applet. |
Mobile Examples
The following table describes how to use the DragAndDrop keyword to drag a record from applet and drop it to a specific field in mobile applications (on mobile devices).
LS Home Page Contact List Applet - Mobile |NULL|3 |
LS Home Page Calendar Applet-Mobile |slotCol-0-08:00 |
Drags a record from the call applet and drops it on the calendar applet (according to the specified rn). |
Draw
You use the Draw keyword to capture the signature.
Signature
The Draw keyword supports the following signature:
Draw(FieldRN)
Desktop and Mobile Examples
The following table describes how to use the Draw keyword to capture a signature in desktop and mobile applications.
FieldRN |
FileDownload
You use the FileDownload keyword to download (and export) a file.
Signature
The ServerConfig keyword supports the following signature:
FileDownload(FileName,ButtonRN/NULL,Save/Cancel)
The file downloads to the following location: C:\\temp\\Download_File.
Desktop Examples
The following table describes how to use the FileDownload keyword to download a file in desktop applications.
abc.txt |
NULL |
Save |
Downloads the file. |
export.csv |
SWE Export Applet.btnNext |
Cancel |
Cancels the download pop-up window. |
Mobile Examples
The FileDownload keyword does not apply to mobile applications.
FileUpload
You use the FileUpload keyword to attach and upload (import) a file.
Signature
The FileUpload keyword supports the following signature:
FileUpload(AppletRN|FieldRN(or)ButtonRN, FileName , ButtonRN/NULL)
Note the following about the FileUpload keyword signature:
Desktop Examples
The following table describes how to use the FileUpload keyword to upload a file to the FileUpload folder in desktop applications.
SWE Import Applet|file |
InputFileSales.txt |
NULL |
Uploads the Sales.txt file to the FileUpload folder. |
UCM List Import Jobs Form Applet - Job Details|FileName |
output.csv |
NULL |
Uploads the output.csv file to the FileUpload folder. |
Mobile Examples
FileUpload Attachment List Applet - Mobile|New File IMG_002.PNG;IPH2;IPH3 NULL
GetAboutRecord
You use the GetAboutRecord keyword to obtain parameter values from the About Record pop-up window and store the values in a user variable.
Signature
The GetAboutRecord keyword supports the following signature:
GetAboutRecord(AppletRN|RN of AboutRecord,RN of Label(1..N)|Variable(1..N))
Desktop Examples
The following table describes how to use the GetAboutRecord keyword to obtain and store information from the About Record pop-up window in desktop applications.
SIS Account List Applet|About Record (SWE) |
Row:|@var1 |
Stores the row field value from the AboutRecord pop-up window in a variable. |
SIS Account Entry Applet|About Record (SWE) |
Row:|@var1,Conflict:|@var2,Created_On:|@var3,Created By:|@var4 |
Stores the Row, Conflict, Created_on, and CreatedBy field values from the About Record pop-up window in a variable. |
Mobile Examples
The following table describes how to use the GetAboutRecord keyword to obtain and store information from the About Record pop-up window in mobile applications (on mobile devices).
SHCE Sales Account List Applet - Mobile|About Record (SWE) |
RowId|@var1,UpdatedOn:|@var2,CreatedOn:|@var3 |
Stores the Row, UpdatedOn, Created_on field values from the About Record pop-up window in a variable. |
GetConfigParam
You use the GetConfigParam keyword to read the values in the config.xml file. The keyword retrieves one value at a time, given the correct parameter name (tagname).
Signature
The GetConfigParam keyword supports the following signature:
Tag name till value/Null;?Required Tagname;Variable
Note the following about the GetConfigParam keyword signature:
All three inputs are mandatory to enter.
If the attribute value to be obtained from the config.xml file is available under any parent tag, then provide the application name in the Inputs column.
If the attribute value to be obtained from the config.xml file is not available under any parent tag (directly), then provide NULL in the Inputs column.
GetRecordCount
You use the GetRecordCount keyword to obtain the total number of records and store the value in a user variable.
Signature
The GetRecordCount keyword supports the following signature:
GetRecordCount(Applet RN|RN of Recordcount Menu item/NULL,Variable)
Desktop Examples
The following table describes how to use the GetRecordCount keyword to obtain the total number of records and store the value in a user variable in desktop applications.
SIS Account List Applet|Record Count (SWE) |
@Var1 |
Stores the total record count in a user variable. |
SIS Account List Applet|NULL |
@Var1 |
Uses NULL for the applets without menu. |
Mobile Examples
The following table describes how to use the GetRecordCount keyword to obtain the total number of records and store the value in a user variable in mobile applications (on mobile devices).
SHCE Sales Account List Applet - Mobile|Record Count (SWE) |
@recordcount |
Stores the total record count in a user defined variable. |
SHCE Sales Account List Applet - Mobile| |
@Var1 |
Uses NULL for the applets without a menu. |
GetState
You use the GetState keyword to obtain the state of a specified object and store the state in a variable. The state of an object can be Read-only, Enabled, Disabled, Editable, and so on.
Signatures
The ServerConfig keyword supports the following signatures:
GetState(AppletRN|FieldRN|[RowNum] ,@Variable) GetState(AppletRN|MenuButtonRN|MenuItemRN ,@Variable) GetState(ApplicationLevelMenuRN|ApplicationLevelMenuItemRN,@Variable)
Desktop Examples
The following table describes how to use the GetState keyword to obtain the state of a specified object and store the state in a variable in desktop applications.
SIS Product List Admin Applet|Release |
@variable1 |
Stores the Release state in a variable. |
SIS Product List Admin Applet|XA Class Name|3 |
@variable2 |
Stores XA Class Name state for the third record in a variable. |
SIS Product List Admin Applet|SiebAppletMenu|Delete Record (SWE) |
@variable3 |
Stores the Delete record (SWE) state in a variable. |
Menu-File|File - Send Fax |
@variable4 |
Stores the File - Send Fax state in a variable. |
Mobile Examples
The following table describes how to use the GetState keyword to obtain the state of a specified object and store the state in a variable in mobile applications (on mobile devices).
SHCE Sales Account List Applet - Mobile|QuerySrchSpec |
@var |
Gets the state of a variable and stores the state in @var. |
SHCE Sales Account List Applet - Mobile|SiebAppletMenu|Record Count (SWE) |
@var |
Gets the state of a menu item and stores the state in @var. |
GetValue
You use the GetValue keyword to obtain the value from a specified object and store the value in a variable.
Signature
The GetValue keyword supports the following signature:
GetValue(AppletRN|FieldRN/ClassName/ThreadbarID|[RowNum/Tileindex],@Variable)
Desktop Examples
The following table describes how to use the GetValue keyword to obtain the value from the specified object and store the value in a variable in desktop applications.
AppletRN|ClassName|[RowNumber] |
@Var |
Gets a value based on Class Name. |
SIS Account List Applet|Account Status|2 |
@Var |
Gets a value from the Account Status field in the second row and stores the value in a variable. |
Opportunity Form Applet - Child|SalesRep2 |
@Var |
Gets a value from the SalesRep2 field in the form applet and stores the value in a variable. |
Opportunity Form Applet - Child|Description2 |
@Var |
Gets the value from the Description2 field in the form applet and stores the value in a variable. |
NULL|Save Query As Applet._SweQueryName |
@Var |
Gets a value from the pop-up input field. |
SIS Account List Applet|Name |
@Var[3] |
Gets a value of first three records in the Accounts list applet. |
Mobile Examples
The following table describes how to use the GetValue keyword to obtain the value from a specified object and store the value in a variable in mobile applications (on mobile devices).
SHCE Sales Account List Applet - Mobile|Name|4 |
@accountname |
Gets a value from the Name field in the fourth row and stores the value in the account name variable. |
SHCE Sales Account List Applet - Mobile|Name |
@accountname |
Gets a value from the Name field in the first row and stores the value in the account name variable. |
GetValueFromMenuPopup
You use the GetValueFromMenuPopup keyword to read values from application level pop-up menus.
Signature
The GetValueFromMenuPopup keyword supports the following signature:
GetValueFromMenuPopup(MenuRN|MenuItemRN,RN_Label(1..N)|Variable(1..N))
Desktop Examples
The following table describes how to use the GetValueFromMenuPopup keyword to read values from application level pop-up menus in desktop applications.
Help|Help - Technical Support |
Application Version|@var1 |
Gets the value in the Application Version field when Help - Technical Support is selected from the application-level menu. |
Help|Help - About Record |
Created By|@var1 |
Gets the value in the CreatedBy field when Help, then Technical Support is selected from the application-level menu. |
Mobile Examples
The GetValueFromMenuPopup keyword does not apply to mobile applications.
GoToSettings
You use the GoToSettings keyword to view and change the default settings of a user profile.
Signature
The GoToSettings keyword supports the following signature:
Gotosettings()
The following table describes how to use the GoToSettings keyword to view and change the default settings of a user profile in desktop and mobile applications.
Navigates to the Settings (user profile) screen. |
GoToThreadbarView
You use the GoToThreadbarView keyword to move to a view in the threadbar.
Signature
The GoToThreadbarView keyword supports the following signature:
GoToThreadbarView(Id of Threadbar Link)
Desktop Examples
The following table describes how to use the GoToThreadbarView keyword to move to a view in the threadbar in desktop applications.
Views_tb_0 |
Clicks on the specified threadbar link. |
Views_tb_1 |
Mobile Examples
The GoToThreadbarView keyword does not apply to mobile applications.
GoToView
You use the GoToView keyword to move to a specified view from the Tab view, Tree view or Site Map view.
Signatures (Desktop)
The GoToView keyword supports the following signature on mobile devices:
GoToView(ScreenRN|ViewRN|Level)
Note the following:
To go to Sitemap: ScreenRN|View RN|NULL
To go to ScreenTab: ScreenRN|View RN|L1
To go to TabView: NULL|ViewRN|L2/L3/L4
Note the following about the GoToView keyword signature:
View levels can be L1, L2, L3, and L4.
Before going to the next level, the user must be in the immediate previous level. For example, if the user has to go to level 3, the user must be in level 2.
Signature (Mobile)
The GoToView keyword supports the following signature on desktop machines:
GotoView(ViewRN)
Desktop Examples
The following table describes how to use the GoToView keyword to move to a specified view in desktop applications.
NULL|Accounts Screen|L1 |
Navigates to the accounts screen, first level view bar. |
NULL|Account List View|L2 |
Navigates to the accounts screen, second level view bar. |
NULL|TNT SHM Opportunity Agenda View|L3 |
Navigates to the accounts screen, third level view bar. |
NULL|Quote Item XA View|L4 |
Navigates to the accounts screen, fourth level view bar. |
Sitemap.Asset Management Screen|Sitemap.Asset Mgmt - Assets View|NULL |
Clicks on the Site Map links. |
Mobile Examples
The following table describes how to use the GoToView keyword to move to a specified view in mobile applications (on mobile devices).
Pharma Contact List View - Mobile |
Navigates to the Contact List view. |
HierarchicalList
You use the HierarchicalList keyword to expand and collapse the Hierarchical List applet, including both parent and child records based on the row number provided. You also use the keyword to obtain the total number of child records in the Hierarchical List applet.
Signature
The HierarchicalList keyword supports the following signature:
HierarchicalList(AppletRN|Rownum,Expand/Collapse/GetChildItemsCount|Variable)
Note the following about the HierarchicalList keyword signature:
Expand is for expanding the record.
Collapse is for collapsing the record.
GetChildItemsCount|@var is for expanding and taking a child count of the record irrespective of whether the record has a child or not.
Desktop Examples
The following table describes how to use the HierarchicalList keyword to expand, collapse and get the child count in desktop applications.
Order Entry - Line Item List Applet (Sales)|1 |
Expand |
Expands the first record. |
Order Entry - Line Item List Applet (Sales)|8 |
Collapse |
Collapses the eighth record. |
Order Entry - Line Item List Applet (Sales)|2 |
GetChildItemsCount|Variable |
Expands the second record and reads the child count in the record. |
Mobile Examples
The HierarchicalList keyword does not apply to mobile applications.
InboundWebServiceCall
You use the InboundWebServiceCall keyword to read an XML request from a .xml file, post the request to the server, and save the XML response from the server. The keyword also verifies the expected TagName and value in the XML response.
Signature
The InboundWebServiceCall keyword supports the following signature:
Inboundwebservicecall(XMLFIle;Tagname|@VAR1,Tagname2|@var2/NULL;Tagname|Value/ @var/@STOREVAR,Tagname|value/@var/@STOREVAR)
Note the following about the InboundWebServiceCall keyword signature:
You must provide the full Tagname in the signature.
The variable name must begin with @STORE to store the response value of a tagname into the variable.
XML structure
To pass the dynamic variable into the XMLFIle PFB, use the following XML structure:
<tagname>$var</tagname> <tagname>="$var"</tagname>
XML Structure
An example of the XML structure is as follows:
<EAI> <EAI-SERVERNAME>Component Alias</EAI-SERVERNAME> <EAI-USERNAME>Username</EAI-USERNAME> <EAI-PASSWORD>Password</EAI-PASSWORD> </EAI>
Desktop Examples
The following table describes how to use the InboundWebServiceCall keyword to read, post, and save an XML request and then verify the response in desktop applications.
Prod1.xml;swip:WorkspaceName|@var,swip:WorkspaceReuseFlag|@var2;ActiveFlag|@STOREVAR |
Stores the tagname value in the response (ActiveFlag) in the @STOREVAR variable. |
Prod1.xml;swip:WorkspaceName|@var,swip:WorkspaceReuseFlag|@var2;ActiveFlag|Y |
Passes the values to a SOAP request dynamically. |
Currency.xml;ConversionRateResult|0.0161 |
Sends the XML request and verifies the response. |
Currency.xml;swip:WorkspaceName|@var,swip:WorkspaceReuseFlag|@var2;ActiveFlag|@var2 |
new.xml;NULL;OrderItem|ProductId|88-46TS9:ActionCode|@STOREsdf |
Stores ActionCode from Order item tags in the @STOREsdf variable with the unique productID 88-46TS9. |
Mobile Examples
The InboundWebServiceCall keyword does not apply to mobile applications.
InputValue
You use the InputValue keyword to enter a value into a field. The keyword supports unique values by adding the dollar ($) symbol to the end of the text. For example, if the input is john$, then a random unique value appends like "john548".
The InputValue keyword supports the following special characters and operators:
* (asterisk). For example: like AAX*.
= (equals). For example: date=Today+1.
+ (plus). For example: Today+1.
- (minus). For example: Today-1.
LIKE, like. For example: date format like, LIKE AAX*.
OR. For example: @var1 OR @var2.
Numerals zero to nine (0 - 9).
Signature
The InputValue keyword supports the following signature:
InputValue(AppletRN|FieldRN|[Active_Record/Tileindex/RowNum],Value OR Variable)
RowNumber is optional. If RowNum is not specified, then RowNum defaults to the first row.
Active_Record obtains the row number of the active record during execution.
If the action is to be performed on tile applets, then the tile index or row number must start from one.
!+! is the delimiter used for concatenating dynamic variable in the middle of input data. For more information, see the examples in the following table.
Desktop Examples
The following table describes how to use the InputValue keyword to enter values into fields in desktop applications.
SIS Account list Applet|Name |
john$ |
Creates a unique value when $ is appended to the end of the value. |
Test!+!@storedVar!+!Kwd |
Appends the dynamic variable value(storedVar) in between static text by using the delimiter !+!. |
SIS Account list Applet|Name|Active_Record |
john$ |
Enters the value in to the field for the highlighted row in the list applet. |
Opportunity Form Applet - Child|CloseDate |
today+10 |
Enters the today+10 value into the CloseDate Field. |
SIS Account List Applet|Main Phone Number |
LIKE 650 |
Enters the phone number LIKE 650*. |
Test1234 |
Enters the value in to the pop-up input field. |
NULL |
Enters the empty value into the input field (Name). |
Mobile Examples
The following table describes how to use the InputValue keyword to enter values into fields in mobile applications (on mobile devices).
SHCE Account Entry Applet - Mobile|Name |
john$ |
SHCE Sales Account List Applet - Mobile|Location|2 |
Paris |
Enters the value into the second row of the list applet. For example, Paris. |
InvokeAppletMenuItem
You use the InvokeAppletMenuItem keyword to call a menu item from an applet-level menu in a list or form.
Signature
The InvokeAppletMenuItem keyword supports the following signature:
InvokeAppletMenuItem(AppletRN|RN of Menu Item,(RN of Closing Action/NULL))
Note the following about the InvokeAppletMenuItem keyword signature:
The Confirmation dialog box does not close after you delete a record.
The VerifyError keyword must be used after the deletion of any record.
Desktop Examples
The following table describes how to use the InvokeAppletMenuItem keyword to call a menu item from an applet-level menu in a list or form in desktop applications.
SIS Account List Applet|New Record (SWE) |
NULL |
Invokes the New Record applet menu item with no action in the pop-up window that appears. |
SIS Account List Applet|Delete Record (SWE) |
NULL |
Invokes the Delete Record applet menu item with no action in the pop-up window that appears. |
CloseApplet |
Invokes the Record Count applet menu item where users must click on OK in the pop-up window that appears. |
CloseButton |
Invokes the About Record applet menu item where users must click on OK in the pop-up window that appears. |
Mobile Examples
The following table describes how to use the InvokeAppletMenuItem keyword to call a menu item from an applet-level menu in a list or form in mobile applications (on mobile devices).
CloseApplet |
Invokes the Record Count applet menu item where users must click OK in the pop-up window that appears. |
SHCE Sales Account List Applet - Mobile|Get Bookmark URL (SWE) |
CloseApplet |
Invokes the Get Bookmark URL applet menu item where users must click OK in the pop-up window that appears. |
InvokeMenuBarItem
You use the InvokeMenuBarItem keyword to call a menu item from the application-level menu.
Signature
The InvokeMenuBarItem keyword supports the following signature:
InvokeMenuBarItem(MenuRN|MenuItemRN)
Desktop Examples
The following table describes how to use the InvokeMenuBarItem keyword to call a menu item from the application-level menu in desktop applications.
Menu-Help|Help - Technical Support |
IPH1;IPH2 ;IPH3 |
OK/CANCEL/NULL |
Selects Technical Support from the (application-level) Help menu. |
Mobile Examples
The InvokeMenuBarItem keyword does not apply to mobile applications.
InvokeObject
You use the InvokeObject keyword to call UI objects such as PickApplet, MVG, Calculator, Currency Image, and so on.
Signature
The InvokeObject keyword supports the following signature:
InvokeObject(AppletRN|FieldRN|[RowNum]/[Active_Record])
Desktop Examples
The following table describes how to use the InvokeObject keyword to call UI objects in desktop applications.
SIS Product List Admin Applet|Product Line |
Invokes the list applet field object. |
SIS Product List Admin Applet|Product Line|3 |
Invokes the list applet field object in the third row. |
SIS Product List Admin Applet|Product Line|Active_Record |
Invokes the list applet field object from the current active row. |
Opportunity Form Applet - Child|Account2 |
Invokes the form applet field object. |
Opportunity Form Applet - Child|Revenue2 |
Invokes a Form applet field object. |
NULL|Revenue2 |
Invokes the object in a pop-up window. |
Mobile Examples
The following table describes how to use the InvokeObject keyword to call UI objects in mobile applications (on mobile devices).
SHCE Sales Opportunity List Applet ReadOnly - Mobile|Primary Revenue Amount|1 |
Invokes the Currency pop-up window. |
SHCE Sales Opportunity List Applet ReadOnly - Mobile|Account |
Invokes the drop-down list applet. |
NULL|Currency Code |
Invokes the Currency code dialog box. |
Launch
You use the Launch keyword to start and log in to applications by providing the username.
Signature
The Launch keyword supports the following signature:
Launch(component_alias;username;Y/N
Note the following about the Launch keyword signature:
Component_alias must come from the predefined component names for a product.
Component_alias and username are mandatory parameters.
[clearBrowser] is an optional parameter, which can be specified if there is a specific requirement to clear cookies at application startup.
By default, cookies are not cleared at application startup.
Desktop Examples
The following table describes how to use the Launch keyword to start and log in to an application by providing the username in desktop applications.
CORE_UIF;SADMIN;Y |
Starts the browser, clears the browser cookies and logs in with the username SADMIN. |
CORE_UIF;SADMIN;N |
Starts the browser and logs in with the username SADMIN. |
CORE_UIF;PortalApplication;Y |
Handles the login page in the Portal application. |
PHARMAM;LaunchApp;Y |
Starts the application. |
Mobile Examples
The following table describes how to use the Launch keyword to start and log in to an application by providing the username in mobile applications (on mobile devices).
PHARMAM;SPORTER |
LockColumn
You use the LockColumn keyword to lock or unlock a selected column.
Signature
The LockColumn keyword supports the following signature:
LockColumn(AppletRN | FieldRN,Lock/Unlock)
Desktop Examples
The following table describes how to use the LockColumn keyword to lock or unlock a selected column in desktop applications.
LOCK |
Locks the selected column. |
UNLOCK |
Unlocks the selected column. |
Mobile Examples
The following table describes how to use the LockColumn keyword to lock or unlock a selected column in mobile applications (on mobile devices).
Contact List Applet - Mobile|First Name |
LOCK |
UNLOCK |
LogOut
You use the LogOut keyword to log out from applications.
Signature
The LogOut keyword supports the following signature:
LogOut
The following table describes how to use the LogOut keyword to log out from applications in desktop applications and mobile.
Logs out from the application. |
MafSettings
You use the MafSettings keyword to perform the required action in the MAF Settings page in MAF applications (on iOS and Android devices).
Signatures
The signature to start the Siebel app is as follows:
Launch(component_alias;LaunchApp;[clearBrowser])
The signature for the MafSettings keyword is as follows:
MafSettings(Action:Id; Value/NULL; OK/CANCEL/NULL)
Note the following about the MafSettings keyword signature:
Action can be one of the following: Input, Click, Verify, verifyerrorMsg, Flip, or Springboard.
Value can be a User input value or NULL.
ClosingAction can be OK, CANCEL, or NULL.
Desktop Examples
The MafSettings keyword does not apply to desktop applications.
Mobile Examples
The following table describes how to use the MafSettings keyword to perform the required action in the MAF Settings page in MAF applications on iOS and Android devices.
Click:setting-fragment2:host__inputElement |
NULL |
NULL |
Clicks host. |
Input:setting-fragment2:host__inputElement |
Servername |
NULL |
Inputs the host value. |
verifyerrorMsg: |
Alert Invalid Host Server Address |
OK |
Verifies the alert message. |
verify:setting-fragment2:host::lbl |
Host;True |
NULL |
Verifies the host. |
flip:sbs-dock__switch |
Y |
NULL |
Flips Enable Show in the dock. |
Springboard:Refresh Button |
NULL |
NULL |
Clicks the Springboard toolbar. |
MultiSelectRecordsInListApplet
You use the MultiSelectRecordsInListApplet keyword to select multiple records in a list applet.
Signature
The MultiSelectRecordsInListApplet keyword supports the following signature:
MultiSelectRecordsinListApplet(AppletRN,RowNum(1..N)
Desktop Examples
The following table describes how to use the MultiSelectRecordsInListApplet keyword to select multiple records in list applets in desktop applications.
AppletRN |
1,3,5 |
Selects first, third, and fifth record from the list applet. |
Mobile Examples
The following table describes how to use the MultiSelectRecordsInListApplet keyword to select multiple records in list applets in mobile applications on (mobile devices).
CG Account List Applet - Mobile |
1,3,5 |
Selects the first, third, and fifth record from the list applet. |
QueryRecord
You use the QueryRecord keyword to query a record in a list or form applet.
Signature
The QueryRecord keyword supports the following signature:
QueryRecord(Applet RN|ButtonRN,FieldRN(1..N)|Value(1...N) OR Variable)
Desktop Examples
The following table describes how to use the QueryRecord keyword to query a record in list or form applets in desktop applications.
Contact List Applet|NewQuery |
Last Name|oracle$,First Name|company$,Work Phone #|6506123456 |
Queries the record with the specified search criteria. |
LastName| David,FirstName|Albert |
First Name|AAAX* |
Work Phone #|650678-0987 |
Opportunity Form Applet - Child|NewQuery |
Opportunity Currency2|USD |
First Name|AAAX* |
First Name|NULL |
Searches for an empty query (that is for records where First Name is NULL). |
M/M|Mr. |
Mobile Examples
The following table describes how to use the QueryRecord keyword to query a record in list or form applets in mobile applications (on mobile devices).
SHCE Sales Opportunity Form Applet - Mobile|NewQuery |
CG Account List Applet - Mobile|NewQuery |
Name|abc |
RemoveFromMvg
You use the RemoveFromMvg keyword to remove a specified record or all records from an MVG list. The "Query:" will be appended to the results after executing the keyword.
Signature
The RemoveFromMvg keyword supports the following signature:
RemoveFromMvg(AppletRN|FieldRN|[RowNum]/ [Active_Record],Query:FieldRN(1…N)(1..N)|Value(1…N:);Remove/RemoveAll;OK/ CANCEL,RN(OK)
Note the following about the RemoveFromMvg keyword signature:
Active_Record is the row number of the active record during execution.
The OK and Cancel options are optional in the input column.
Desktop Examples
The following table describes how to use the RemoveFromMvg keyword to remove a specific or all records from an MVG list in desktop applications.
SIS Account List Applet|Sales Rep |
Active Last Name|Silver,Active First Name|Victor;Remove |
RN of OK |
Removes an account team from an account in a list applet. |
SIS Account List Applet|Sales Rep|Active_Record |
RN of OK |
Removes an account team from an account in a list applet. Performs the action on the field of the active row. |
SIS Account Entry Applet|SalesRep |
Active Last Name|Dupont,Active First Name|Dupont;Remove |
RN of OK |
Removes an account team from an account in a form applet. |
NULL;RemoveAll |
RN of OK |
Removes all accounts in a list applet. |
NULL;RemoveAll;OK |
RN of OK |
Removes all accounts in a list applet. Users must click OK on confirmation. |
Mobile Examples
The following table describes how to use the RemoveFromMvg keyword to remove a specified or all records from an MVG list in mobile applications (on mobile devices).
SHCE Sales Account List Applet - Mobile|Primary Account Address Name |
Name|abc;RemoveAll |
Idcancel |
Name|abc;Remove |
Idcancel |
Removes an account in a list applet. |
SelectCheckBox
You use the SelectCheckBox keyword to select or clear a check box.
Signature
The SelectCheckBox keyword supports the following signature:
SelectCheckbox(AppletRN|FieldRN|[RowNum],TRUE(or)FALSE(or)@variable)
Desktop Examples
The following table describes how to use the SelectCheckBox keyword to select or clear a check box in desktop applications.
Opportunity List Zpplet|Committed |
TRUE |
Selects the check box. |
SIS Account List Applet|Fund Eligible Flag|3 |
FALSE |
Clears the check box in the third row of the list applet. |
Opportunity List Applet|Committed |
@Variable |
Selects or clears the check box depending on the variable value (True or False). |
MultiAdd Product On Order|Select All|Select All |
True/False |
Selects the check box in the column header. |
Mobile Examples
The following table describes how to use the SelectCheckBox keyword to select or clear a check box in mobile applications (on mobile devices).
SHCE Address List Applet - Mobile|SSA Primary Field |
TRUE |
Selects the check box for the specified object based on the provided user value. |
SHCE Address List Applet - Mobile|SSA Primary Field|3 |
FALSE |
Clears the check box for the specified object based on the provided user value. |
SelectFromMvg
You use the SelectFromMvg keyword to select a specified record after querying the available records in an MVG.
Signature
The SelectFromMvg keyword supports the following signature:
SelectFromMvg(AppletRN|FieldRN|[RowNum]/ [Active_Record],FieldRN(1…N)|Value(1…Nb),RN of OK)
Desktop Examples
The following table describes how to use the SelectFromMvg keyword to select a specified record after querying the available records in an MVG in desktop applications. The Query will be appended to the results after executing the keyword.
Query:Last Name|Yang |
Idok |
Selects a Sales Rep after querying the available records in an MVG. |
Idok |
Selects a Sales Rep after querying the available records in an MVG of the active record. |
Mobile Examples
The following table describes how to use the SelectFromMvg keyword to select a specified record after querying the available records in an MVG in mobile applications (on mobile devices).
Query:Name|abc |
Idcancel |
Selects a name after querying the available records in an MVG. |
SelectFromPickApplet
You use the SelectFromPickApplet keyword to query and select the first record from a drop-down list applet.
Signature
The SelectFromPickApplet keyword supports the following signature:
SelectFromPickApplet(AppletRN|FieldRN|[RowNum]/ [Active_Record],Query:FieldRN(1…N)|Value(1…Nt),RN(OK/CANCEL))
Note the following about the SelectFromPickApplet keyword signature:
RowNum is an optional value. If RowNum is not specified, then RowNum defaults to the first row.
Desktop Examples
The following table describes how to use the SelectFromPickApplet keyword to query and select the first record from a drop-down list applet in desktop applications.
Query:City|Berkeley |
Idcancel |
Queries and cancels the first value in a drop-down list applet form. |
Account Profile Applet|Price List |
Query:Name |ACR764 Price List,Start Date|7/16/2007 05:00:00 |
PMPopupQueryPick |
Queries and selects the first value in a drop-down list applet. |
Contact List Applet|Account|1 |
Query:Name|Hibbing |
PopupQueryPick |
Queries and selects the first value in a drop-down list applet form. |
Contact List Applet|Account|Active_Record |
PopupQueryPick |
Queries and selects the first value in a drop-down list applet (in active record). |
Query:Currency Code|USD |
PopupQueryPick |
Mobile Examples
The following table describes how to use the SelectFromPickApplet keyword to query and select the first record from a drop-down list applet in mobile applications (on mobile devices).
SHCE Sales Account List Applet - Mobile|Parent Account Name |
Query:Name|abc |
PopupQueryPick |
SHCE Sales Contact List Applet - Mobile|NewRecord |
Query:Last Name|abc |
AddRecord |
Queries and selects the first value in a drop-down list applet form (having clicked the plus (+) icon in the list applet). |
SelectPDQValue
You use the SelectPDQValue keyword to select a value from the Predefined Query (PDQ) list in the application.
Signature
The SelectPDQValue keyword supports the following signature:
SelectPDQValue(ItemRN OR Variable)
Desktop Examples
The following table describes how to use the SelectPDQValue keyword to select a value from the PDQ list in desktop applications.
Account |
Selects a PDQ value named <abc>. |
@Variable |
Selects a PDQ value stored in a variable. |
Mobile Examples
The following table describes how to use the SelectPDQValue keyword to select a value from the PDQ list in mobile applications (on mobile devices).
Account |
@Variable |
SelectPickListValue
You use the SelectPicklistValue keyword to select a value from the drop-down list in a form or list applet.
Signature
The SelectPicklistValue keyword supports the following signature:
SelectPicklistValue(AppletRN|FieldRN|[RowNum]/[Active_Record],Value(or)Variable)
Desktop Examples
The following table describes how to use the SelectPicklistValue keyword to select a value from the drop-down list in a form or list applet in desktop applications.
Active |
Sets a value in a drop-down list of a particular field in the second row of the list applet. |
SIS Account List Applet|Account Status|Active_Record |
Active |
Sets a value in a drop-down list of a particular field in the active row of the list applet. |
SIS Account List Applet|Account Status |
@Variable |
Sets a value (by using a variable) in a drop-down list of a particular field in a list applet. |
Opportunity Home Search Virtual Form Applet|SalesStage |
@Variable |
Sets a value (by using a variable) in a drop-down list of a particular field in a form applet. |
Mobile Examples
The following table describes how to use the SelectPicklistValue keyword to select a value from a drop-down list in a form or list applet in mobile applications (on mobile devices).
SHCE Account Entry Applet - Mobile|Type |
Customer |
Selects a value from a drop-down list or LOV (List of Values) in a form or list applet. |
SHCE Sales Account List Applet - Mobile|Type |
@var |
Sets a value in a drop-down list of a particular field in the second row of a list applet. |
SHCE Sales Account List Applet - Mobile|Type|1 |
@var |
SelectRadioButton
You use the SelectRadioButton keyword to select a radio button.
Signatures
The SelectRadioButton keyword supports the following signatures:
SelectRadioButton(AppletRN|FieldRN ,Value OR Variable) SelectRadioButton(NULL|FieldRN ,Value) SelectRadioButton(AppletRN|FieldRN ,Variable)
Desktop Examples
The following table describes how to use the SelectRadioButton keyword to select a radio button in desktop applications.
Sort Order Popup Applet (SWE)|rdbDesc1 |
Ascending |
Selects a specified radio button. |
NULL|SWE Export Applet.rdbRowsToExport |
All Rows In Current Query |
@Variable |
Selecta a variable value radio button. |
Mobile Examples
The SelectRadioButton keyword does not apply to mobile applications.
You use the SelectRecordInListApplet to select a particular record in a list applet.
Signature
The SelectRecordInListApplet keyword supports the following signature:
SelectRecordinListApplet(AppletRN|FieldRN|[RowNum/Tileindex],Value/Variable/NULL)
Desktop Examples
The following table describes how to use the SelectRecordInListApplet keyword to select a particular record in a list applet in desktop applications.
Metropolitan Investments |
Selects the specified field value record in the list applet. |
AppletSIS Account List Applet|Name|5 |
NULL |
Selects a record (the fifth record) based on the specified row index (5). |
NULL |
Selects the fifth record in the list applet. |
AppletQuote List Applet|Quote Number |
@Variable |
Selects the specified field value from a variable record in the list applet. |
AppletSIS Account List Applet|Name|4 |
Abc |
Selects the specified row (or fourth record) in the list applet. |
Mobile Examples
The following table describes how to use the SelectRecordInListApplet keyword to select a particular record in a list applet in mobile applications (on mobile devices).
AppletRN|FieldRN|[RowNumber] |
Value |
Selects a record in the list applet, according to the specified input value. |
AppletSHCE Sales Account List Applet - Mobile|Name|1 |
FinanceOne Corporation |
Selects the specified value in the specified row number. |
Matches the value in the visible records. |
@accountName |
Matches the field value in a variable record. |
SelectToggleValue
You use the SelectToggleValue keyword to select a value from a toggle control in a list applet.
Signature
The SelectToggleValue keyword supports the following signature:
SelectToggleValue(AppletRN|ToggleRN,Value)
Desktop Examples
The following table describes how to use the SelectToggleValue keyword to select a value from a toggle control in a list applet in desktop applications.
SIS Account List Applet|SiebToggle |
Accounts |
Selects the specified value from the toggle control in a list applet. |
Pharma Calendar Activity List Applet|SiebToggle |
1 |
Note: Input "1" represents the "value" attribute in DOM
Mobile Examples
The SelectToggleValue keyword does not apply to mobile applications.
SelectVisibilityFilterValue
You use the SelectVisibilityFilterValue keyword to select a value from the Visibility Filter drop-down list in an applet.
Signature
The SelectVisibilityFilterValue keyword supports the following signature:
SelectVisibilityFilterValue(AppletRN|ItemRN)
Desktop Examples
The following table describes how to use the SelectVisibilityFilterValue keyword to select a value from the Visibility Filter drop-down list in desktop applications.
SIS Account List Applet|All Account List View |
Selects the All Account list view from the Visibility Filter drop-down list. |
Contact List Applet|Manager's Contact List View |
Selects the Manager's Contact list view from the Visibility Filter drop-down list. |
Mobile Examples
The SelectVisibilityFilterValue keyword does not apply to mobile applications.
SendKeys
You use the SendKeys keyword to trigger keyboard events.
Signature
The SendKeys keyword supports the following signature:
SendKeys(Keystroke)
Note the following about the SendKeys keyword signature:
You must use SendKeys only if the test case requires an action to be performed using the keyboard.
You must open SendKeys in Inetpub.
You must enable screenshot for test steps when using SendKeys for debugging.
Before performing a SendKeys action, the focus must be on the object.
Avoid using the keyboard (including SendKeys) during unit testing of the test cases.
During batch execution, the computer window in which execution occurs must be closed, to avoid sending false key input.
Special characters keys are supported, including combinations of the following:
Lowercase a to z.
Uppercase A to Z.
Numerals 1 to 9.
The following keyboard keys are supported:
ADD; ALT; ARROW_DOWN; ARROW_LEFT; ARROW_UP; ARROW_RIGHT; BACK_SPACE; CANCEL; CLEAR; COMMAND; CONTROL; DELETE; DECIMAL; DIVIDE; DOWN; END; ENTER; EQUALS; ESCAPE; F1; F2; F3; F4; F5; F6; F7; F8; F9; F10; F11; F12; HELP; HOME; INSERT; MULTIPLY; NUMPAD0; NUMPAD1; NUMPAD2; NUMPAD3; NUMPAD4; NUMPAD5; NUMPAD6; NUMPAD7; NUMPAD8; NUMPAD9; PAGE_DOWN; PAGE_UP; SHIFT LEFT; RIGHT; SPACE; SUBTRACT; TAB; UP; BRACERIGHT; BRACELEFT
Desktop Examples
The following table describes how to use the SendKeys keyword to trigger keyboard events in desktop applications.
CTRL+ALT+N |
Selects all records. |
CTRL+S |
Saves. |
CTRL+TAB |
Tabs out. |
SetDateTime
You use the SetDateTime keyword to call the DateTime or Date pop-up calendar specify the date and time.
Signature
The SetDateTime keyword supports the following signature:
SetDateTime(AppletRN|FieldRN|[RowNum]/[Active_Record],today(+/-))
Note the following about the SendDateTime keyword signature:
If the time is not specified, then the default time is 00:00:00. Value can be a DATETIME, a DATE, or a Variable.
Desktop Examples
The following table describes how to use the SetDateTime keyword to call the DateTime or Date pop-up calendar to provide the date and time in desktop applications.
Opportunity Form Applet - Child|CloseDate2 |
DD:MM:YYYY;01:01:2015 |
Chooses a date in the Calendar pop-up window. |
Activity List Applet With Navigation|Planned |
Today |
Sets the current date and time. |
Activity List Applet With Navigation|Planned|Active_Record |
Today |
Sets the current date and time in the field of the active record. |
DD:MM:YYYY:HH:MM:SS;05:08:2014 : 10:17:20 |
Sets the specified date and time. |
Today+365 |
Sets the specified date plus (+)365 days. |
Today-365 |
Sets the specified date minus (-) 365 days. |
28|01|CURRENTYEAR |
Sets a specified date in the current year. |
28|01|CURRENTYEAR-1 |
Sets the specified date in the previous year. |
28|01|CURRENTYEAR+2 |
Sets the specified date in the current year plus (+)2. |
Mobile Examples
The following table describes how to use the SetDateTime keyword to call the DateTime or Date pop-up calendar to provide the date and time in mobile applications (on mobile devices).
SHCE Sales Contact Opportunity List Applet - Mobile|Primary Revenue Close Date |
Today |
SHCE Sales Opportunity Quote List Applet ReadOnly - Mobile|Start Date |
Today+9 |
SHCE Quote Entry Applet - Mobile|StartDate |
DD:MM:YYYY;11:05:2014 |
Sets the specified date in the target object. |
SHCE Sales Order Entry List Applet - Mobile|Order Date |
DD:MM:YYYY:HH:MM:SS; 11:5:2014:12:12:30 |
Sets the specified date and time in the target object. |
DD:MM:YYYY:HH:MM:SS; 1:8:2014:12:30:20 |
SortColumn
You use the SortColumn keyword to sort a selected column.
Signature
The SortColumn keyword supports the following signature:
SortColumn(AppletRN | FieldRN,ASC/DESC)
Desktop Examples
The following table describes how to use the SortColumn keyword to sort a selected column in desktop applications.
Opportunity List Applet|Primary Revenue Amount |
ASC |
Sorts the columns in ascending order. |
SIS Account List Applet|Type |
DESC |
Sorts the columns in descending order. |
Mobile Examples
The following table describes how to use the SortColumn keyword to sort a selected column in mobile applications (on mobile devices).
SHCE Account Team List Applet - Mobile|Active Last Name |
ASC |
SHCE Sales Contact List Applet - Mobile|First Name |
DESC |
TreeExplorer
You use the TreeExplorer keyword to perform operations in the explorer tree applet, such as, expand and collapse the tree, select any item in the tree, and show the child items.
Signature
The TreeExplorer keyword supports the following signature:
TreeExplorer(TreeAppletRN|Tree_id,Expand/Collapse/SelectTreeItem/ GetTreeChildItemsCount|@var/IsNodeExists[;@Var;True/ False;GetTreeChildItemsCount|@var])
Desktop Examples
The following table describes how to use the TreeExlorer keyword to expand, collapse, select items from, and show the child items under an explorer tree in desktop applications.
Account Tree Applet|1.9 |
Expand |
Expands the tree structure. |
Collapse |
Collapses the tree structure. |
IsNodeExists |
Verifies the existence of a node. |
IsNodeExists;@Var;True/False |
Verifies the existence of a node in the case of a negative scenario. |
SelectTreeItem |
Selects the specified tree item. |
Account Tree Applet|1.2 |
GetTreeChildItemsCount|@var |
Obtains the number of child items and saves the value in a variable. |
Mobile Examples
The TreeExplorer keyword does not apply to mobile applications.
VerifyColumnLockStatus
You use the VerifyColumnLockStatus keyword to verify the lock status of a column.
Signature
The VerifyColumnLockStatus keyword supports the following signature:
VerifyColumnLockStatus(AppletRN | FieldRN,Lock/Unlock
Desktop Examples
The following table describes how to use the VerifyColumnLockStatus keyword to verify the lock status of a column in desktop applications.
LockStatusSIS Account List Applet|Name |
LOCK |
Verifies the lock status of the specified column. |
UNLOCK |
Verifies the unlock status of the specified column. |
Mobile Examples
The following table describes how to use the VerifyColumnLockStatus keyword to verify the lock status of a column in mobile applications (on mobile devices).
LockStatusContact List Applet - Mobile|First Name |
LOCK |
UNLOCK |
VerifyColumnSortOrder
You use the VerifyColumnSortOrder keyword to verify the order of records in a selected column.
Signature
The VerifyColumnSortOrder keyword supports the following signature:
VerifyColumnSortOrder(AppletRN | FieldRN,ASC/DESC)
Desktop Examples
The following table describes how to use the VerifyColumnSortOrder keyword to verify the order of records in a selected column in desktop applications.
ASC |
Verifies that records are sorted in ascending order. |
DESC |
Verifies that records are sorted in descending order. |
Mobile Examples
The following table describes how to use the VerifyColumnSortOrder keyword to verify the order of records in a selected column in mobile applications.
ASC |
DESC |
VerifyError
You use the VerifyError keyword to verify the error messages that appear in applications i.e., Siebel error pop ups’.
Signature
The VerifyError keyword supports the following signature:
VerifyError(ExpectedMessageSubstring1|ExpectedMessageSubstring2|…..ExpectedMessage SubstringN,OK/CANCEL)
Desktop Examples
The following table describes how to use the VerifyError keyword to verify the error messages that appear in applications in desktop applications.
| Target Object | Inputs | Closing Action | Comments |
'Duration' is a required field|Please enter a value for the field.|SBL-DAT-00498 |
OK |
Verifies whether the error message, which appears in the application, contains the specified string value or not. (The Pipe separator is used a separator to verify multiple strings.) |
'Duration' is a required field. Please enter a value for the field.(SBL-DAT-00498) |
OK |
To verify if the complete error message is displayed correctly. |
Mobile Examples
The following table describes how to use the VerifyError keyword to verify the error messages that appear in applications in mobile applications (on mobile devices).
OK |
Verifies whether the error message, which appears in the application, contains the specified string value or not. |
VerifyFileLoad
You use the VerifyFileLoad keyword to perform image validation, such as, checking that the image has downloaded completely (100% download) and the image filename.
Signature
The VerifyFileLoad keyword supports the following signature:
VerifyFileLoad(AppletRN|ImageFileName|TilePosition,Y/N [Full Download])
Desktop Examples
The following table describes how to use the VerifyFileLoad keyword to perform image validation in desktop applications.
eDetailer Messaging Plan Items Preview List Applet - Mobile|ThumbnailFN3_01132017.jpg|1 |
Y |
Verifies that the image has downloaded completely. |
eDetailer Messaging Plan Items Preview List Applet - Mobile|ThumbnailFN3_01132017.jpg |
Y |
Mobile Examples
Verifyfileload eDetailer Messaging Plan Items Preview List Applet - Mobile|ThumbnailFN3_01132017.jpg|1 Y
VerifyFocus
You use the VerifyFocus keyword to verify the focus location in an application. Focus can be on one of the following in an application: list, form, view, field, or rows in an applet.
Signature
The VerifyFocus keyword supports the following signature:
VerifyFocus(AppletRN(or)ViewRN|FieldRN,TRUE/FALSE)
Note the following about the VerifyFocus keyword signature:
The True and False input covers the following scenarios:
Use False to check that focus is not on a particular applet, field, or row.
Use True to check that focus is on a particular applet, field, row, application-level menu, or application-level menu item.
Desktop Examples
The following table describes how to use the VerifyFocus keyword to verify the focus location in desktop applications.
TRUE |
Verifies that focus is on the specified list applet. |
FALSE |
Verifies that focus is not on the specified list applet. |
SIS Account List Applet|Row Status|2 |
TRUE |
Verifies that focus is on the specified field in the list applet. |
SIS Account Entry Applet|Name |
TRUE |
Verifies that focus is on the specified field in the form applet. |
FALSE |
Verifies that focus is not on the specified field in the form applet. |
SIS Account List Applet|2 |
TRUE |
Verifies that focus is on the specified row number in the list applet. |
FALSE |
Verifies that focus is not on the specified row number in the list applet. |
SIS Account List Applet|2,3 |
TRUE |
Verifies that focus is on the specified row numbers in the list applet. |
Search Admin|NULL |
TRUE |
Verifies that focus is on the specified view. |
Menu-File|Null |
TRUE |
Verifies that focus is on the application-level menu. |
Menu-File|Null |
FALSE |
Verifies that focus on the application-level menu. |
Menu-File|File - Custom Print |
TRUE |
Verifies that focus is on the application-level menu item. |
FALSE |
Mobile Examples
The following table describes how to use the VerifyFocus keyword to verify the focus location in mobile applications (on mobile devices).
TRUE |
SHCE Sales Account List Applet - Mobile|NULL |
TRUE |
TRUE |
SHCE Sales Account List Applet - Mobile|1 |
TRUE |
VerifyInPicklist
You use the VerifyInPicklist keyword to count the number of items in a drop-down list, auto select using the substring, and verify whether the values exist or not in the drop-down list without selecting the values.
Signature
The VerifyInPicklist keyword supports the following signature:
VerifyInPicklist(AppletRN|FieldRN|[RowNum],Count:operator,value(or) Variable;True/ False [AutoSelect]: [Exists]: value or variable; True/false)
Desktop Examples
The following table describes how to use the VerifyInPicklist keyword to verify the values in a drop-down list in desktop applications.
SIS Account List Applet|Type|1 |
Count;=;118|True |
Verifies that all values (118) are present in the Type drop-down list. |
AutoSelect;contains;ac|TRUE |
Verifies that there are values that contain the keyword ac. |
Exists;=;Customer123|True |
Verifies whether a value exists or not. |
Opportunity Form Applet - Child|SalesStage2 |
AutoSelect;starts;App|TRUE |
Verifies that there are values that start with App. |
Mobile Examples
Verifies the color of the picklist value.
Cfg Cx Runtime Instance Frame (JS HI)|RF1060
_Accessory_DOMAINSELECT
color:RED;=;RF1060_Packof10Zip Disks|TRUE
Verify that the items in the Accessories pick list are showing up in RED.
VerifyObject
You use the VerifyObject keyword to verify the presence of an object or UI name in applications.
Signature
The VerifyObject keyword supports the following signature:
VerifyObject(AppletRN|FieldRN/MenuItemRN,UN name/data-caption of MenuItem/Inner Text or Title for field items/NULL; TRUE/FALSE)
Note the following in the VerifyObject keyword signature:
Use NULL as the input to verify the existence of an object
Use the object label (for example, the name of a button) as the input to verify the object name.
Use the menu item label as the input to verify the menu item name.
Use the field label as the input to verify the field name or title.
True or False input is mandatory.
If the True parameter is set and if the expected object does not match the actual object in the UI, then the test step fails.
If the True parameter is set and if the expected object matches the actual object in the UI, then the test step passes.
If the False parameter is set and if the expected object does not match the actual object in the UI, then the test step passes.
If the False parameter is set and if the expected object matches the actual object in the UI, then test the step fails.
Desktop Examples
The following table describes how to use the VerifyObject keyword to verify the presence of an object or UI name in desktop applications.
NULL;TRUE |
Verifies the existence of an applet. |
NULL|SUI_OPEN_TOOLBAR |
NULL;TRUE |
Verifies that the toolbar is open. |
NULL|SUI_CLOSED_TOOLBAR |
NULL;TRUE |
SIS Account List Applet|SiebVisList |
All Accounts Across Organizations;TRUE |
Verifies that the item exists in the Visibility list in the list applet. |
SIS Account List Applet|DeleteRecord |
NULL;TRUE |
Verifies that the Delete button exists in the list applet. |
Delete;TRUE |
Verifies that the Delete button UI name exists in the list applet. |
SIS Account Entry Applet|DeleteRecord |
NULL;TRUE |
Verifies that the Delete button exists in the form applet. |
SIS Account List Applet|NewQuery |
NULL;TRUE |
Checks that the NewQuery button exists in the list applet. |
Account Type;TRUE |
Checks that the Column Account Type exists in the list applet. |
SIS Account List Applet|QueryComboBox |
NULL;TRUE |
Verifies that the QueryComboBox drop-down list exists in the list applet. |
About Record [Ctrl+Alt+K];TRUE |
Verifies that the menu item About Record (SWE) exists in the list applet. |
SIS Account List Applet|Account Type Code|1 |
Customer;TRUE |
Checks the title of the Account Type Code field with the row number in the list applet. |
Menu-File|File - Create Bookmark |
Create Bookmark…;TRUE |
Verifies that the application menu item Create Bookmark exists in the file menu. |
All Rows In Current Query;TRUE |
Verifies that the Radio button exists in the pop-up. |
Accounts List;TRUE |
Verifies that the application links exist. |
Delete;FALSE |
Verifies the absence of the Delete button UI name in the list applet (negative scenario). |
Mobile Examples
The following table describes how to use the VerifyObject keyword to verify the presence of an object or UI name in mobile applications (on mobile devices).
AppletRN|FieldRN |
FieldUN;TRUE/FALSE |
Verifies the UI name of the field. |
SHCE Sales Account List Applet - Mobile|NewQuery |
Query;TRUE |
Verifies that the Query button exists in the list applet. |
Accounts;TRUE |
Verifies that items exist in the QuerySearch text box in the list applet. |
SHCE Sales Account List Applet - Mobile|DeleteRecord |
Delete;TRUE |
SHCE Sales Account List Applet - Mobile|QueryComboBox |
NULL;TRUE |
Customer;TRUE |
NULL|Account List View |
VerifyRecordCount
You use the VerifyRecordCount keyword to verify the number of records (the record count) in a list applet.
Signature
The VerifyRecordCount keyword supports the following signature:
VerifyRecordCount(AppletRN|Rn of record count from the list/Form applet menu/ NULL,Operator,Value(or)@Variable)
Note the following about the VerifyRecordCount keyword signature:
The following operators are supported: greater than (>), greater than or equal to (>=), less than (<), less than or equal to (<=), equals (<>).
If using NULL, then the record count is verified in a pop-up window or applet that does not have an applet menu.
Desktop Examples
The following table describes how to use the VerifyRecordCount keyword to verify the number of records in a list applet in desktop applications.
>=,6 |
Verifies if the count is greater than or equal to 6. |
<=,6 |
Verifies if record count is less than or equal to 6. |
<>,6 |
Verifies if the record count with less than or greater than 6. |
< ,6 |
Verifies the record count is less than 6. |
> ,6 |
Verifies if the record count is greater than 6. |
> =,@var |
Verifies if the record count is greater than or equal to any variable. |
> =,2 |
Verifies if the record count is greater than or equal to 2. |
Mobile Examples
The following table describes how to use the VerifyRecordCount keyword to verify the number of rcords in a list applet in mobile applications (on mobile devices).
>,6 |
Verifies if the record count is greater than or equal to 6. |
<,@var |
Verifies if the record count is less than any variable. |
<,2 |
Verifies if the record count is less than 2. |
VerifyState
You use the VerifyState keyword to verify the state of an object.
Signatures
The VerifyState keyword supports the following signatures:
VerifyState(AppletRN|FieldRN|[RowNum] ,TRUE/FALSE) VerifyState(AppletRN|MenuButtonRN|MenuItemRN ,TRUE) VerifyState(ApplicationLevelMenuRN|ApplicationLevelMenuItemRN,TRUE)
Note the following about the VerifyState keyword signature:
If an object is enabled, editable, or drillable, then verification is True.
If an object is disabled or read only, then verification is False.
You can verify the state of most objects, including the following: button, text, check box, drop-down list, menu item, application-level menu items.
Desktop Examples
The following table describes how to use the VerifyState keyword to verify the state of an object in desktop applications.
SIS Product Form Applet - ISS Admin|NewRecord |
TRUE |
Verifies whether the button state is enabled or disabled. |
SIS Product List Admin Applet|Billable Flag|3 |
FALSE |
Verifies whether the check box field is enabled or disabled. |
SIS Product Form Applet - ISS Admin|SiebAppletMenu|New Record (SWE) |
TRUE |
Verifies the state of menu item in the form applet. |
Menu-Query|Query - QueryAssist |
FALSE |
Verifies the state of application level menu items. |
NULL|Tree |
TRUE |
Verifies the state of the application. |
NULL|Tab |
TRUE |
NULL|Side Menu |
TRUE |
Mobile Examples
The following table describes how to use the VerifyState keyword to verify the state of an object in mobile applications (on mobile devices).
TRUE |
Verifies the state of the variable and stores the value in @var. |
TRUE |
Verifies the state of the menu item. |
VerifyTopNotification
You use the VerifyTopNotification keyword to verify whether or not a notification message appears in the application. The keyword also verifies the color of the notification.
Signature
The VerifyTopNotification keyword supports the following signature:
VerifyTopNotification((MessagebroadcastRN,Expectedmessage|[ExpectedHeader];Color|E xpectedd Color/NULL|Match/NoMatch,Close/KeepOpen))
Desktop Examples
The following table describes how to use the VerifyTopNotification keyword to verify whether or not a notification message appears in desktop applications.
MsgBrdCstIcon |
Account_10142015_041 155918;NULL;Match |
Close |
Verifies whether or not the top unread message appears in the notification list, and closes the control. |
MsgBrdCstIcon |
Account_10142015_041 155918;NULL;NoMatch |
Close |
MsgBrdCstIcon |
Account_10142015_041 155918;Color|Red;Match |
Close |
Verifies whether the color of the top unread message in the notification list matches the input value, and closes the control. |
MsgBrdCstIcon |
KeepOpen |
Verifies whether the color of the top unread message in the notification list matches the input value, and keeps the control open. |
MsgBrdCstIcon |
SVP Action|populate Actions;NULL;Match |
Close |
Verifies whether the top unread message in the notification list matches the input value, and closes the control. |
Mobile Examples
The following table describes how to use the VerifyTopNotification keyword to verify whether or not a notification message appears in mobile applications (on mobile devices).
MsgBrdCstIcon |
Data synchronization notification|Data is ready for download;NULL;Match |
Close |
Verifies whether or not the top unread message appears in the notification list, before going offline and closing the control. |
VerifyValue
You use the VerifyValue keyword to verify a field value by comparing the field value with a user variable (input value).
Signature
The VerifyValue keyword supports the following signature:
VerifyValue(AppletRN|FieldRN|[RowNum]/[Active_Record],Operator,Value(or)@Variable)
Note the following about the VerifyValue keyword signature:
If performing the action on tile applets, then the tile index and row number must start with one.
The row number is optional. If RowNum is not specified, then RowNum defaults to the first row.
The following operators are supported: greater than (>), greater than or equal to (>=), less than (<), less than or equal to (<=), not equals (<>), contains, startswith, endswith, LIKE, etc.
Desktop Examples
The following table describes how to use the VerifyValue keyword to verify a field value by comparing the field value with a user variable (input value) in desktop applications.
Contact List Applet|StartDate |
=,Today |
Verifies the field value by comparing it with the input value. |
=,Y |
Verifies the check box field value by comparing it with the input value. |
Contact List Applet|M/M|2 |
=,Mr. |
=,@Var1 |
SIS Account List Applet|Name|2 |
=,@Var1 |
Contact List Applet|Last Name |
startswith,Ab |
Verifies the field value by comparing it with the input value, starts with Ab. |
<>,A* |
Verifies the field value by comparing it with the input value, not equal to A. |
Opportunity List Applet|Name |
=,LIKE Q* |
<>,"Q* |
"Verifies the field value by comparing it with the input value. |
Mobile Examples
The following table describes how to use the VerifyValue keyword to verify a field value by comparing the field value with a user variable (input value) in mobile applications (on mobile devices).
=,AG Edwards & Sons, Inc |
=,@accountname |
startswith,Ab |
=,A |
Keywords Supporting Tools and Server Configuration
The following keywords support Siebel Tools and Siebel Server configuration for mobile application:
The following prerequisites are requried to use these keywords:
Strawberry Perl must be installed and setup.
Strawberry Perl must be installed on client machines.
InvokePerl
You use InvokePerl keyword to execute a Perl file.
Signature supported:
InvokePerl(Select Machine|scriptname.pl:@VAR/String[String1,String2....N]/NULL|Output Variable)
Select Machine::SiebelServer Machine or TestHarness Machine :SiebelServer Reads server credentials from xml file and executes the Perl file on Server Machine.
TestHarness Machine:Executes the perl file locally.
Scriptname.pl:: Perl script to be executed.
@VAR/String[String1,String2....N:: Variable support or Strings to be passed to the perl file.
@Output Variable:: Variable support to get the value from the perl file.
End of the Perl file user should print the PerlExecStatus in the PerlFile.(as below example).
print"PerlExecStatus = $PerlExecStatus";
To save value into a variable , please use the syntax in the perl File.
print"\@invokePerl1=$ARGV[1].";
print"\@invokePerl2=$ARGV[0].";
print"perlexecstatus = $PerlExecStatus";
Pre-requisite:
Folder Structure: All the user defined perl files and cmd.txt for execution should be placed in Resources/invokePerl Folder in TestHarness.
The exe files folder should be placed in the framework\exe in TestHarness.
Update the following tags in config.xmlSIEBEL-SERVER-NAME=macihne-name ----SERVER_MACHINE will be passed as $ARGV [0] to the perl file
SIEBEL-SERVER-MACHINE-LOGIN-ID=userid ----SERVER_LOGIN will be passed as $ARGV [1] to the perl file
SIEBEL-SERVER-MACHINE-PASSWORD=pwd ----SERVER_LOGIN will be passed as $ARGV [2] to the perl file
SIEBEL-SERVER-OS-TYPE=WINDOWS ----SERVER_OS_TYPE will be passed as $ARGV [3] to the perl file
SERVER-DB-TYPE=MSSQL ----SERVER_DB_TYPE will be passed as $ARGV [4] to the perl file
SERVER_DB_NAME=dbname ----SERVER_DB_NAME will be passed as $ARGV [5] to the perl file
DBSERVER-AND-PORT=dbserver,port ----DBSERVER_AND_PORT will be passed as $ARGV [6] to the perl file
DB-TABLE-OWNER=XYZ ----DB_TABLE_OWNER will be passed as $ARGV [7] to the perl file
DB-SERVER-LOGIN=SADMIN|MSSQL ----DBSERVER_Login will be passed as $ARGV [8]&& $ARGV [9] to the perl file
TEST-MACHINE-NAME=machinename ----CLIENT_MACHINE will be passed as $ARGV [10] to the perl file
----------- ----TestHarness Path $ARGV[11]
SIEBEL-GATEWAY-PORT=servername:port ----ENTSERVER_AND_PORT will be passed as $ARGV[12]
SERVER-INSTALLATION-PATH ----C:\\23044\\ses\\siebsrvr\\BIN ----SERVER INSTALLATION PATH will be passed as $ARGV[13]
------------- ----Exefiles folder location will be passed as $ARGV[14]
Variable passed from script ----Will be passed as $ARGV[15]
[PERL-PATH]
Ex: PERL-PATH= \\\\servername\\install\\PERL_UTILS\\Perl1\\bin\\perl.exe
Examples:
| Keyword | Target Object | Inputs | Closing Action |
Keyword |
Target Object |
Inputs |
Closing Action |
InvokePerl |
SiebelServer Machine;test.pl:NULL;NULL |
InvokePerl |
SiebelServer Machine;test.pl:value1,value2;NULL |
InvokePerl |
SiebelServer Machine;test.pl:value1;NULL |
InvokePerl |
SiebelServer Machine;test.pl:value1,@invokePer;NULL |
InvokePerl |
SiebelServer Machine;test.pl:@invokePerl;NULL |
InvokePerl |
SiebelServer Machine;test.pl:@invokePerl,@invokePerl;NULL |
InvokePerl |
SiebelServer Machine;test.pl:@invokePerl,@invokePerl;@invokePerl1 |
InvokePerl |
SiebelServer Machine;test.pl:@invokePerl,@invokePerl;@invokePerl1,@invokePerl2 |
InvokePerl |
TestHarness Machine;test.pl:NULL;NULL |
InvokePerl |
TestHarness Machine;test.pl:value1,value2;NULL |
InvokePerl |
TestHarness Machine;test.pl:value1,@invokePerl;NULL |
InvokePerl |
TestHarness Machine;test.pl:@invokePerl,@invokePerl;@invokePerl1 |
InvokePerl |
TestHarness Machine;test.pl:@invokePerl,@invokePerl;@invokePerl1,@invokePerl2 |
ToolsConfig
You use ToolsConfig keyword to apply Siebel customizations by importing pre-exported sif files using Web tools.
ToolsConfig(Sif1,Sif2|Merge/Overwrite|branch$,workspace$)
-Sif files needs to be copied in SiebelTestAutomation\Resources\toolsconfig folder.
-Resources files needs to be zipped and attached to the Master suite attachment applet.
-STE run will copy Resources.zip to the client machine and unzip the same while execution.
Create a Integration branch using Webtools.
Create a Workspace under the newly created branch using Webtools.
Import the SIF files through CLI.
Create a Checkpoint, Submit, Deliver using Webtools.
After completing the ‘toolsconfig’ keyword, user may execute ‘change_branch.txt’ file with server restart using ‘serverconfig’ keyword to change the application branch. The command in the ‘change_branch.txt’ is shown below,
Example: For callcenter application: change param WorkspaceBranchName=int_branch for comp SCCObjMgr_enu
PERL-PATH
SIEBEL-TOOLS-MACHINE
SIEBEL-TOOLS-PATH
SIEBEL-TOOLS-USER-NAME
SIEBEL-TOOLS-PASSWORD
DSN-NAME
DATABASE-USERID
DATABASE-PASSWORD
[PERL-PATH]
Ex: PERL-PATH= \\slcnas607\\karta\\ATF_QTP\\Perl\\bin\\perl.exe
Examples:
| Keyword | Target Object | Inputs | Closing Action | Comments |
ToolsConfig |
RTC.sif|Merge|branch$,workspace$ |
Importing and compiling single sif file. |
ToolsConfig |
RTC.sif ,RTC1.sif,RTC2.sif|Overwrite|branch$,workspace$ |
Importing and compiling multiple sif file. |
Toolsconfig Revert option:
Once the user completes the Testing in 'Integration' branch, to change the application from Integration branch to MAIN branch, user should execute a command in server manager using 'serverconfig' keyword.
Example : For Call Center application : "change param WorkspaceBranchName=MAIN for comp SCCObjMgr_enu"
change_branch.txt file:
change_branch.txt file will have the command to change the application from MAIN branch to Integration branch.
ServerConfig
You use the ServerConfig keyword to configure and bounce the Siebel server.
ServerConfig(Y)
ServerConfig(commandsFile.txt)
SERVER:Machine where Siebel server is running. Machine details will be available in SERVER-LOGIN-CREDENTIAL tag which is available in config.xml.
commandsFile.txt:Text file containing the list of commands to be executed in server manager
Pre-requisite:
Folder Structure: All the Perl files related to serverconfig keyword should be available in framework\perl folder in Test Harness
ServerConfig is a composite keyword which includes the following:
Launch server manager
Command to be executed
Stop ses/swsm
Stop sieb server
Start ses/swsm
Start sieb server
[PERL-PATH]
SERVER-OS-TYPE
AI-SERVER-PORT
SERVER-HOME-PATH
GATEWAYSERVER-TSLPORT
Examples:
ServerConfig |
Y;NULL;IPH3 |
Bounce the SERVER. |
ServerConfig |
N;cmd.txt;IPH3 |
Connect to server manager ,execute the commands in cmd.txt file. |
ServerConfig |
Y;cmd.txt;IPH3 |
Connect to server manager ,execute the commands in cmd.txt file and bounce the SERVER. |
Unsupported Keywords for Siebel Open UI Keyword Automation
The following keywords are not supported for Siebel Open UI keyword automation testing.
Calendar(Change slot of Call/Activity)
Dispatch Board
Oracle Policy Automation (Third Party Control)
Find Result Pane
Search Result Pane
Gantt DragAndDrop
Charts
Promotion Designer
Gantt (Diary)
Task Pane items
Gantt Chart - Promotion List
Script recorded in any language for e.g. DEU - can be play backed in same language i.e. in DEU
Script recorded in ENU language – can’t be play backed in any other NONENU language like DEU, JPN etc.
You can make a note of the different scenarios and the corresponding values to be entered in the resource.xml file.
| S.No. | Scenario where Resource file needs to be updated | Value needs to be updated in Resource File |
1 |
Column Display (Hide, Show, MovingUP, MovingDown |
Selected Field Value should be entered Resource File |
2 |
Verify the Error/Warning message |
Error/Warning message in NONENU Language |
3 |
Toggle Value |
Selected Togglevalues should be entered in NONENU languages |
4 |
Verify Short Date |
Short Date in correspending NONENU language format |
5 |
Verify Long Date |
Long Date in correspending NONENU language format |
6 |
Verify Date Time |
Date Time in correspending NONENU language format |
7 |
Verify Value - Numeric |
Numeric value should be entered in correspending NONENU language format |
8 |
Verify Value - String |
Translated string value |
9 |
Verify Value - DateTime/Date |
Date Time in correspending NONENU language format should be entered |
10 |
Any string value present in Combo box |
Data LIC value should be entered |
11 |
Visibilty DropDown value |
Translated value of visibilty dropdown should be entered |
12 |
Verifies Button Existence/Absence |
Translated name of the button should be entered |
13 |
Verifies Column name Existence/Absence |
Translated name of the column should be entered |
14 |
Verifies Menu Item Existence/Absence |
Translated name of the MenuItem should be entered |
15 |
Verifies Existence/Absence of Label of any field |
Translated name of the Label should be entered |
16 |
Verifies the Presence/Absence of RadioButton on the Popup |
Translated value of radio button label should be entered |
17 |
Compare strings values |
Translated string value should be entered |
18 |
Compare numeric values |
19 |
Compare date/DateTime values |
Date/DateTime value should be entered in correspending NONENU language format |
20 |
Picklist applet -if any combo box value need to be selected |
21 |
MVG applet -if any combo box value need to be selected |
22 |
Application level Menu Item verification |
23 |
Selection of Radio button in export and import |
Labels translated value should be entered |
24 |
Selection of Radio button in Advance Sort |
LIC values of dropdown should be entered |
25 |
In simple query - query with any combo box value |
Data LIC value should be entered for query combo box |
26 |
Verify the Application level Menu Enable/Disable |
Translated value of Application level menu should be entered |
27 |
Verify the Applet level Menu Enable/Disable |
Translated value of Applet level menu should be entered |
28 |
Verify Label in any form applet |
Translated value of Label should be entered in File |
29 |
Verify applet level record count (1 - 30 of 30+) |
Transalated Record count value should entered in file |
30 |
Applet level search option |
Data LIC value for combo box value should be entered |
