23Siebel Upgrade Planning Worksheet
This chapter contains the Upgrade Planning Worksheet. Before you upgrade your Siebel application, photocopy this worksheet, complete it, and give a copy to each member of the upgrade team.
The Upgrade Planning Worksheet contains the following sections:
Team Lead Summary
The following table shows the Team Lead Summary fields to complete on the Upgrade Planning Worksheet.
Field |
Description or Value |
Deployment Team Lead: |
Siebel Administrator: |
Privileged User/Siebel Database User: |
DB2 Systems Programmer (SYSADM): |
DB2 Database Administrator (DBADM): |
Security Administrator: |
z/OS System Programmer: |
Midtier System Administrator: |
DB2 Connect Information
The following table shows the DB2 Connect Information fields to complete on the Upgrade Planning Worksheet.
Field |
DB2 Host Name/IP Address: |
DB2 Port Number: |
Siebel Development Environment Information
The following table shows the Development Environment Information fields to complete on the Upgrade Planning Worksheet.
Field |
Siebel Gateway Server: |
Enterprise Server Name: |
Siebel Server Directory: |
Siebel Database Configuration Utilities Directory: |
Database Alias: |
Siebel Administrator User Name: |
Siebel Administrator Password: |
Siebel Administrator User Group: |
Staging Siebel Schema Qualifier ID (Max. 8 chars): |
Staging ODBC Data Source Name (Subsystem name): |
Staging Database User Name: |
Target Siebel Schema Qualifier ID (Max. 8 chars): |
Target ODBC Data Source Name (Subsystem name): |
Target Database User Name: |
Target Security Group ID: |
EIM User Group ID (Max. 8 characters): |
Siebel User Group ID (Max. 8 characters): |
Storage Control Filename: |
Storage Group for Temporary Indexes: |
Database Name Prefix (Max. 4 characters): |
4-KB Bufferpool: |
8-KB Bufferpool: |
16-KB Bufferpool: |
32-KB Bufferpool: |
Index Bufferpool: |
Siebel Production Environment Information
The following table shows the Production Environment Information fields to complete on the Upgrade Planning Worksheet.
Field |
Database Alias: |
Staging Siebel Schema Qualifier ID (Max. 8 chars) |
ODBC DSN for Development Database: |
Database User Name for Development Database: |
Database Table Owner for Development Database: |
Import Repository Name: |
4-KB Bufferpool: |
8-KB Bufferpool: |
16-KB Bufferpool: |
32-KB Bufferpool: |
Index Bufferpool: |
z/OS Host System Variables Information
The following table shows the z/OS Host System Variables Information fields to complete on the Upgrade Planning Worksheet.
Field |
DSN High Level Qualifier Name (DSNHLQ): |
Host/LPAR Name: |
DB2 WLM Name: |
DB2 WLM Load Library Name: |
Code Page / CCSID: |
DB2 Load Libraries: |
Staging Database: |
Target Database: |
