Adding a Block Conversion
Select the Administration menu, select Booking, select Block Management, and then select Conversions.
Code. Enter a code (up to 10 characters) for the conversion rating.
Description. Enter a text description of the conversion rating.
Sequence. Enter a number that controls the position of this code in listings. Codes without a sequence number assigned are listed in alphabetical order following codes with a sequence assigned.
Click Save.
Editing a Block Conversion
Enter search criteria and click Search.
In the search results, select the code and click the vertical ellipsis.
Click Edit.
Only the Description or Sequence can be edited.
Inactive. Select to mark this code inactive. Inactive codes are not available for selection from lists in OPERA Cloud. The code remains for historical and statistical purposes only.
Update the configuration and click Save.
Deleting a Block Conversion
Click Delete and confirm the deletion.
Parent topic: Block Configuration Overview
