Supported Platforms
Platforms
- Netra X3-2 — Ships with the Operating System and software installed.
- Netra X5-2 — Ships with the Operating System and software installed.
- Netra X7-2 — You must
install the Operating System and software from a USB memory device.
- Go to My Oracle Support (MOS) at https://support.oracle.com to download the Operating System and software. See "Download Software from MOS."
- See "Software Installation - Oracle X7-2 Platforms" in the Oracle Enterprise Session Border Controller Installation and Platform Preparation Guide on https://docs.oracle.com/cd/E95619_01/index.htm for installation instructions.
Image and Boot Loader Files
The PCZ3.1.0 release uses the following image and boot
loader files:
- Image—nnPCZ310.bz
- Boot loader—nnPCZ310.boot
Default Cores and Threads
The following list shows the default number of cores and the expected number of SIP threads per platform. Note that the number of SIP threads may vary, depending on the configuration of your deployment.
- VM—Default 5 cores. Yields 3 SIP threads.
- Netra X3-2, Netra X5-2, and Netra X7-2—Default16 cores. Yields 9 SIP threads.
