PreviousNextJavaScript must be enabled to correctly display this content
Download Software from MOS
When you want to get a software release or a patch
from Oracle, go to My Oracle Support (MOS) and download it to your system or to
a USB memory device.
Establish an account with
My Oracle Support.
The following procedure requires you to enter your MOS credentials to
log on.
Go to
https://support.oracle.com and log on.
Click the
Patches
& Updates tab.
On the Patch Search
pane, click the
Search tab.
On the Search
dialog, do the following:
Product
is—Select a product from the drop-down list.
Release
is—Select a release from the drop-down list.
Click
Search.
On the Patch
Advanced Search Results page, click the patch that you want.
The system displays information about the patch, and a
dialog where you can open the Read Me file and download the software.
