Caveats
The following items describe caveats in the P-CZ3.1.0 release.
LDAP Support
Only the default "ecb" network can support LDAP. Additional networks cannot.
Registrar Support
Only the default "ecb" network can act as the registrar. Additional networks cannot.
Set Initial Configuration Appears to Stall
When attempting to run "Set Initial Configuration" from the GUI, the operation may stall while displaying the following "Backup Complete" message:
Work-around: Refresh the browser, log back into the GUI, and run Set Initial Configuration again.
Call Routing
The ECB cannot route a call when the "Name or Pattern" parameter in the User Database includes the + character.
ECB Sync Compatibility
ECB Sync is supported only between nodes with similar platforms. For example, a mix of X3/X5/X7 is supported, but not a VM and X7.
Deprecated Ciphers
- All DES-CBC ciphers,
including:
- TLS_DHE_RSA_WITH_DES_CBC_SHA
- TLS_RSA_EXPORT1024_WITH_DES_CBC_SHA
The ACLI may still display these ciphers when you run cipher-list ?, but the system does not support them.
