Known Issues
The following table lists Known Issues and provides the Service Request ID number, a description of the issue, any workaround, when the issue occurred, and when Oracle fixed the issue. This table includes issues from previous releases that either remain open or are resolved in this release. Issues from previous releases that do not appear here do not apply to this release. You can also find information about resolved issues in the Build Notes for this release.
| ID Number | Description | Found In | Fixed In |
| 29401925 |
The GUI does not allow you to edit a user database entry that contains an Address of Record. Work-around: Delete the entry and add it as a new entry with the changes that you want. |
PCZ3.1.0 | PCZ3.1.0p2 |
| No ID number |
If you want to establish a High Availability pair that uses IP addresses other than the defaults, perform the following procedure. Use this procedure regardless of whether the ECBs run on virtual or physical systems. The IP addresses you use must be available and valid in your network. If not, you must directly connect the two ECBs before performing this procedure to establish the HA pair initially. Note
Procedure
PCZ3.0.0 | |
| 28314178 |
When you turn on SIP debugging, you may see various unrelated messages displayed on the console. The messages do not prevent the ECB from generating logs, but they can make the console hard to use. Work-around: Use SSH when you turn on SIP debugging. |
PCZ3.0.0 | PCZ3.1.0p2 |
| No ID number |
If you see mapping errors after upgrading, for example errors about redundancy or media traffic, you may need to swap interface addresses. Work-around: Compare the MAC addresses on your Virtual Machine
(VM) to those on your hardware. If the addresses are different, you need to
swap interface addresses. Set the addresses on the hardware to match those from
your VM. Use the
swap command from
the ECB command line.
PCZ3.0.0 | PCZ3.1.0 |
| 30576125 | The ECB is reporting session limit inaccurately. | PCZ3.1.0p2 | PCZ3.1.0p3 |
| 30574675 | Inbound TLS fragmented packet failure when using Acano. | PCZ3.1.0p1 | PCZ3.1.0p3 |
| 30355590, 30406870, 30464332
Some versions of ECB unable to load on some versions of OCSDM. | PCZ3.0.0p4 | PCZ3.1.0p3 |
