PreviousNextJavaScript must be enabled to correctly display this content
Download a File
Use this procedure to download a file from the
Oracle Enterprise Communications
Broker (OECB).
You can download any of the following file types from your local
server or PC to the
OECB:
Backup Configuration
CSV File
Local Subscriber Table
(LRT)
Log
Software Image
SPL Plug-in (SPL)
Access File
Management:
System,
File
Management.
On the File
Management page, select the type of file you want to download from the File
type list.
Place your cursor
on the row of the file that you want to download.
For Log file
types, you can select multiple log files to download, or place a checkmark in
the box to the left of the Name column heading to select all log files to
download. When downloading multiple log files, the File Management GUI
compresses the files into one .tar file and downloads that file to your local
server or PC.
Right-click the
selected row, and click
Download.
Do one of the
following:
Click
Open
With and select the application to open the file.
Click
Save
File to save the file to your local server or PC.
Click
OK.
The system downloads the file to the folder on your local
server or PC where your Browser sends all downloads (typically your “Download”
folder) or opens (decompresses) the file type on your local server or PC
(typically in the “Download” folder).
