Delete a File
Use this procedure to delete a file from the Oracle Enterprise Communications Broker (OECB).
You can delete any of the following file types from your local server or PC to the OECB:
  • Local subscriber table (LST)
  • SPL Plug-in (SPL)
  • Backup configuration
You can select a single or multiple files to delete.
  1. Access the File Management page. Click System, File Management.
  2. On the File Management page, select the type of file that you want to delete from the OECB from the File type drop-down list.
  3. In the Name column, select the check box by the name of file that you want to delete.
    For Log file types, place a checkmark in the box to the left of the “Name” column heading to select all log files to delete.
  4. Click Delete.
    The system prompts you to confirm that you want to delete the file.
  5. Click Yes to delete the file from the OECB.
