PreviousNextJavaScript must be enabled to correctly display this content
Back up a File
You can backup a configuration file from the
Oracle Enterprise Communications
Broker (OECB) to your local server or PC. Backup allows you to save configurations that you can restore to the
OECB at a later time.
From the Web GUI, click
System.
In the Select the file type field, select Backup configuration.
Select one or more configuration files to backup to your server or PC.
Click
Backup.
Click
OK to backup the configuration.
The system downloads the file to your server or PC, typically into the download directory.
