Restore a File You can restore a backed up configuration file to the Oracle Enterprise Communications Broker (OECB). In the Select the file type field, select Backup configuration. Select a backup file to restore to the OECB. Note:Restore activates only when you select a backup file. Click Restore. Click Yes. The system downloads the backup file to the OECB. The OECB re-boots and restores the configuration from the backup file.
