Importing
The import command imports data from a previously exported file into the currently-selected configuration. If no configuration was selected, a new one is created. The syntax is import [FILENAME]. Include the .gz extension in the filename. After importing, type done to save the configuration.
Importing a configuration with the same key as one that already exists returns an error. In this case:
- Delete the object with the same key and re-import.
- Select the object with the same key and perform an import that will overwrite it with new data.
