PreviousJavaScript must be enabled to correctly display this content
Using SFTP to Move Files
After exporting a configuration, use SFTP to copy the file to other
Oracle Enterprise Communications
Brokers. Place the file in the
/code/imports directory before using the
import command on the second
OECB.
