PreviousNextJavaScript must be enabled to correctly display this content
View A Widget That is Not on the Dashboard
The Dashboard is limited to displaying a maximum of 18 widgets. To
see a widget that is not on the Dashboard, use the Widgets link on the
Monitoring page to see a list of all of the Widgets.
Use the following
procedure to view widgets that are not displayed on the Home page as Dashboard
widgets.
Access Widgets:
Monitoring,
Widgets.
In the navigation
pane, click a Dashboard Widget name.
The system displays the Widget.
Optional—Add the
widget to the Dashboard, if the Dashboard is not full.
