System Reboot
You can manually reboot the Oracle Enterprise Communications Broker (OECB) from the Web GUI. Note that when you reboot the system from the Web GUI, the Web GUI is unavailable until the reboot is complete. If you have a High Availability (HA) deployment, connectivity to the secondary OECB stops until the reboot is complete.
When the reboot is complete, the primary and secondary systems each display the logon screen. You must manually log on to each system.
| When you perform a reboot from the Web GUI | The system behaves |
| and no boot is in process and the system is not failing over to the secondary system in an HA environment | the GUI session closes and the system displays the Logon screen. You cannot log on to the Web GUI until the reboot is complete on the OECB. |
| and a reboot is already in progress | the system displays a message indicating that a reboot cannot occur. The first reboot must complete before another reboot is initiated. |
| and the primary system is currently failing over to the secondary system in an HA environment | the system displays a message indicating that a reboot cannot occur. The HA switch over is underway. The secondary OECB is updating and getting its configuration from the primary OECB. |
