Upgrade Software - Web GUI System Tab
You can upgrade the system software from the System tab on the Web GUI. The system requires a reboot after the upgrade.
- From the GUI, click the System tab.
- Click Upgrade Software.
- Click Verification.
- Verify that system health, synchronization health, current configuration version, and disk usage are appropriate and adequate for the upgrade.
From the drop-down
list, select
Upload Method, and select one of the following
methods.
- Local—Use to select a file from your system for transfer.
- Flash—Use to select a file already on the device.
- Network—Use to specify parameters for network boot by way of file transfer.
The system displays the Upgrade Software dialog with the fields required for your upgrade. -
Complete the
required fields.
- Software file to upload. (Local) Use Browse to locate the file on your local system.
- Software file. (Flash) The location and name of the file on the device.
- Boot file. (Network) The complete name of the boot file.
- Host IP. (Network) The IP address of the FTP server.
- FTP username. (Network) The user name to log onto the FTP server.
- FTP password. (Network) The password to log onto the FTP server.
- Optional. Select Reboot After Upload.
Click
Complete.
- If you did not select Reboot After Upload, the system displays a message stating that a reboot is required for the changes to take effect.
- If you selected Reboot After Upload, the system displays a message stating that it is about to reboot.
Click
OK.
If you selected Reboot After Upload, the system reboots.
