Enable Automatic CSV Configuration File Uploads
When you want the Oracle Enterprise Communications Broker (OECB) to automatically update the .csv configuration file, you must enable the service.
- Prepare the .csv file for upload with any additions, modifications, or deletions.
- Go to Configuration, General, System config.
On the System
config page, do the following:
- Enable CSV Upload—Select to enable. Default: Disabled.
- Click OK.
- Save the configuration.
