Test Usage Limitations
Depending on the kind of device that is used for matching, different sets of test functions are available:
B2BUA
Supports SIP matching which comprises these tests:
call_id,uri_user,time_diff, thehf_equalsfamily of tests andsdp_session_idas well assdp_media_ip_port.STP
Supports ISUP call matching with
cdpn,cgpnandtime_diffas tests.SGW
Supports all the tests available for the other two device types and the
cxpn_uritest.
