Getting Started
To get started with using the new REST API please make sure you have your API Key enabled as described in "API Key".
To test if everything is setup correctly please open a terminal window and have your API Key ready. We are going to use the curl command to call the REST API. Please note that this is an example. What we are doing is essentially just placing a HTTPS request with a custom header -X-Api-Key (the custom header contains the API Key). (We use the -k option to make sure that we don't run into any certificate complications when using the API).
Example call:
curl -k -X POST -H "X-API-Key: musterman;samplehexcode" https://mypalladion.com/me/saveApplianceConfiguration
Please replace musterman;samplehexcode with your personal API Key. If the API Key is correct and all parameters are provided as per reference, then the HTTP response will be 200 OK with the JSON response containing a success field that will have the value true.
