First Aid
In case you have a problem, please follow this checklist:
Re-read the corresponding passages in the manual. Some features have special requirements, so make sure to check out these as well. For example, previous configurations, which may be covered in a different context.
Try to find your problem in the list of suggestions in "Suggestions for Specific Error Cases".
If you can't find a solution for your problem, you should create a system diagnostic report from Platform Setup Application and notifying your Operations Monitor support contact.
