Syntax
Syntax wise, they are formed from a single LISP expression. Apart from the tests, there is only the special function cond, and two terminals:
#tfor true.#ffor false.
The LISP cond function accepts an arbitrary number of arguments. Each argument is a list of two elements: a condition and a result.
(cond (condition1 result1) (condition2 result2) ... (conditionN resultN) )
The conditions are evaluated in order, and for the first being true, the result is returned:
if condition1 is true return result1, else if condition2 is true return result2, else if ...; else if conditionN is true return resultN.
If none of the conditions is true, then false is returned for the whole expression, as a convenience.
Usually in call merging algorithms, the conditions are tests and the results are terminals:
(cond (test1 #t) (test2 #t) (test3 #f) (test4 #t) )
But the result does not have to be a terminal. For example, this is a possible AND statement:
(cond (test1 test2) )
The result part can also be another cond expression for providing nested tests:
(cond (test1 (cond (test2 #t) (test3 #t) ) ) (test4 #t) )
The above example translates in the following pseudo-code:
if test1: if test2: return True elif test3: return True else: return False elif test4: return True else: return False
The tests can accept an arbitrary number of parameters which have to be provided right after the test name, for example:
(cond (test1 param1 param2) )
translates to:
if test1(param1, param2): return True else: return False
The parameters can be strings, integers, or list of strings:
(test "string" 12 ("list" "of" "parameters"))
Line comments can be inserted by using the semicolon symbol:
; this is a comment
