Post-Installation Configuration
This section explains security configuration to complete after Session Monitor is installed.
Changing the Default Administrator Passwords
All Session Monitor products (Operations Monitor, Fraud Monitor, and Mediation Engine Connector) are installed with a default admin account. The admin account is used to access the product's Web interface. On first login, the administrator is prompted to choose a unique password for the admin account. Fraud Monitor currently does not prompt to choose a password; the administrator should change the password manually.
You can also connect to each product's Web interface and change the admin account password at any time.
The Platform Setup Application is installed with a default sysadmin account. On each Session Monitor machine, log into the Platform Setup Application, and change the sysadmin account password.
Password Enhancements
Software release version 4.2 and later support complexity requirements for passwords. After upgrading to 4.2 or later, the system will accept old passwords but force users to reset their password to meet the complexity requirements.
Passwords must have the following characteristics:
- At least 8 characters
- At least one uppercase character
- At least one digit
- At least one special character
Encryption and Certificates
All Session Monitor interfaces can only be accessed through encrypted (secure) HTTPS connections. Each Session Monitor machine uses a unique certificate to establish secure connections and to guarantee its authenticity and protect users' data.
The certificates are automatically generated on the Session Monitor machines during the installation process. The certificates are initially self-signed, and when a user accesses the interface the first time, a This Connection is Untrusted warning message is shown. To improve security of the connections and to suppress the warning message, Oracle recommends that you sign the server certificate using your organization's Public Key Infrastructure (PKI).
Consult with your network administrator and follow the steps on the Server Certificate page in Platform Setup Application to sign the certificates of each Session Monitor machine.
Enable Skip hostname validation for HTTPS connection when using self-signed certificates that were generated during installation.
Figure 4-1 shows the Server Certificate page in Platform Setup Application.
Figure 4-1 Server Certificate Page
The Status of the Server Certificate from Platform Setup Application, Subject Alternative Name(s): (none) indicates that SAN is not defined.
On the Trusted Certificate page, the list of trusted certificates also displays the SAN for each certificate.
Figure 4-2 Trusted Certificate Page
Connection Between Mediation Engine and Aggregation Engine
The Aggregation Engine machines can only access the Mediation Engine machines using HTTPS. Make sure that the URLs entered in the Aggregation Engine to access the Mediation Engine machines start with https://.
For a successful secure connection between Mediation Engine and Mediation Engineer Connector each machine has to have a valid certificate for the other machine. This can be either the certificate found on the Server Certificate page of the other machine (self-signed) or the corresponding CA certificate (of the CA that signed the certificate).
For more information, see Session Monitor Mediation Engine Connector User's Guide.
Connection Between Mediation Engine and Interactive Session Recorder
Mediation engine requires a valid Interactive Session Recorder certificate to establish secure and validated connection. The supported certificate format is PEM.
For more information, see Oracle Communications Operations Monitor User's Guide.
