Oracle® Communications Binding Support Function Cloud Native Installation and Upgrade Guide Release 1.0 F16985-01 |
![]() Previous |
![]() Next |
CREATE USER 'bsfusr'@'%' IDENTIFIED BY 'bsfpasswd'; GRANT ALL PRIVILEGES ON *.* TO 'bsfusr'@'%';
Login to MySQL console as a new user created above:
mysql -h<MYSQL_HOST>
-u<USERNAME> -p<PASSWORD>
Execute the below script to initial Binding Support Function databases. At first login to MySQL console via new user created above,
mysql
-h<MYSQL_HOST> -ubsfusr -pbsfpasswd
CREATE DATABASE IF NOT EXISTS `ocpm_config_server`; CREATE TABLE IF NOT EXISTS `ocpm_config_server`.`topic_info` ( `id` bigint(20) NOT NULL AUTO_INCREMENT, `description` varchar(255) COLLATE utf8_unicode_ci DEFAULT 'Default Topics.', `name` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL, `modify_date` datetime NOT NULL DEFAULT CURRENT_TIMESTAMP, `version` int(11) NOT NULL, PRIMARY KEY (`id`), UNIQUE KEY `UK_gd6b0a6mdpxc55qbibre2cldc` (`name`) ) AUTO_INCREMENT=3 DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci; CREATE TABLE IF NOT EXISTS `ocpm_config_server`.`configuration_item` ( `id` bigint(20) NOT NULL AUTO_INCREMENT, `cfg_key` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL, `md5sum` varchar(255) COLLATE utf8_unicode_ci DEFAULT NULL, `cfg_value` mediumtext COLLATE utf8_unicode_ci, `version` int(11) NOT NULL, `topic_info_id` bigint(20) NOT NULL, PRIMARY KEY (`id`), KEY `FKdue8drxn6acrdt63iacireky1` (`topic_info_id`) ) DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci; insert into `ocpm_config_server`.`topic_info` (name, version) values ('policy', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('policySchema', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('policyElement', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('policyParam', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('policygui', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.global.cfg', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.smservice.cfg', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.public.sessionrule', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.public.sessionruleprofile', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.public.authorizeddefaultqos', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.public.pccrule', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.public.qosdata', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.public.chargingdata', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.public.pccruleprofile', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('amservice.system', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('public.matchlist', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pe.serviceTag', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pe.policyTag', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pe.logLevel', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.amservice.app', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('nrfclient.cfg', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('NRF.UDR', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('NRF.BSF', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.userservice.cfg', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('NRF.CHF', 1); insert into `ocpm_config_server`.`topic_info` (name, version) values ('pcf.chfservice', 1); CREATE DATABASE IF NOT EXISTS `ocpm_bsf`; CREATE TABLE IF NOT EXISTS ocpm_bsf.pcf_binding ( binding_id binary(16) not null, ipv4_addr varchar(64), ip_domain varchar(128), ipv6_prefix varchar(64), mac_addr_48 varchar(64), dnn varchar(128), supi varchar(64), gpsi varchar(64), snssai_sd varchar(64), snssai_sst integer, created_date_time datetime(6) not null, json_content longblob not null, primary key (binding_id), key idx_created_date_time (created_date_time), key idx_ipv4Addr (ipv4_addr, created_date_time), key idx_ipv6Prefix (ipv6_prefix, created_date_time), key idx_macAddr48 (mac_addr_48, created_date_time), key idx_supi (supi, created_date_time), key idx_gpsi (gpsi, created_date_time) );
