Go to primary content
Oracle® Communications Binding Support Function Cloud Native Installation and Upgrade Guide
Release 1.0
F16985-01
Contents
Previous
Next
Installation Sequence
This section provides the order in which you shall perform the BSF installation.
Create a MySQl database account. See
Creating Database Account on MySQL Database
Download BSF package files and load them to the system. See
Installation Preparation
Prepare all variables for Helm install command. See
Table 2-3
BSF Deployment using Helm command. See
Deploying Binding Support Function
Verify BSF Deployment. See
Verifying Installation
Configure BSF. See
Configuring Binding Support Function
