Go to primary content
Oracle® Communications Binding Support Function Cloud Native Installation and Upgrade Guide
Release 1.0
F16985-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Pre-requisites
Following are the pre-requisites before installing Binding Support Function.
BSF Software
BSF software includes:
Software Version
Kubernetes v1.12.5
HELM v2.11.0
MySQL 5.7 or later
Additional software that needs to be deployed as per the requirement of the services:
Software Chart Version Notes
elasticsearch 1.21.1 Needed for Logging Area
elastic-curator 1.2.1 Needed for Logging Area
elastic-exporter 1.1.2 Needed for Logging Area
logs 2.0.7 Needed for Logging Area
kibana 1.5.2 Needed for Logging Area
grafana 2.2.0 Needed for Metrics Area
prometheus 8.8.0 Needed for Metrics Area
prometheus-node-exporter 1.3.0 Needed for Metrics Area
metallb 0.8.4 Needed for External IP
metrics-server 2.4.0 Needed for Metric Server
tracer 0.8.3 Needed for Tracing Area
In case any of the above services are needed and the respective software is not installed in CNE. Install the software before proceeding with BSF installation.
If you are using NRF, install it before proceeding with the BSF installation.
Network Access
The Kubernetes cluster hosts must have network access to:
  • quay.io/datawire/ambassador docker image repository
  • Local helm repository where the Oracle Communications Binding Support Function helm charts are available
  • Local docker image repository where the Oracle Communications Binding Support Function images are available
Laptop/Desktop Client Software
Following are the requirements for the laptop/desktop where the deployment commands shall be executed:
  • Network access to the helm repository and docker image repository
  • Helm repository must be configured on the client
  • Network access to the Kubernetes cluster
  • Necessary environment settings to run the kubectl commands. The environment should have privileges to create namespace in the Kubernetes cluster.
  • Helm client installed with the push plugin. The environment should be configured so that the helm install command deploys the software in the Kubernetes cluster.
Browser Support
It is recommend to use Firefox browser to access Kubernetes dashboard. The Configuration Management GUI page is accessed from different browsers.
Server or Space Requirements
For server and space requirements, refer to Oracle Communications Cloud Native Environment Installation Guide.
